Messaggio da SashaCX75 »
toolsrme
Has thanked: 9 times
Messaggio da toolsrme »
@SashaCX75 -
This watch face editor is really saving me a bunch of time on tweaking stuff. Just curious though about a couple of things...
  • I see the skins in the applications Skin folder, can those be used and if so how?
  • Same with the shortcut pointer in the Mask folder?
Thanks again. Your app is making everything so much easier.
The use of skins is enabled in the settings. They are used when saving the preview in a png or gif file.
The use of shortcut pointer is also enabled in the settings. It is only used when saving the preview to a gif file.
Max88
Messaggio da Max88 »
Hello guys. I need help with this watchface:
https://amazfitwatchfaces.com/gts/view/8791
I'd like to understand how has the autor managed to reproduce the behaviour of original watchface of apple watch.
When I load this watchface inside this editor I don't understand where the 12 images have been assigned.
Is there anyone who could help?
I neither see the images in preview, and nothing in json
edit:
for example download the version:
applestyle_contour_rainbow_v0_eng
as you can see I don't see those images
Been thanked: 2122 times
Messaggio da asoo »
Max88 ha scritto: 21 gen 2024, 15:41
edit:
Because of the dial you mentioned. The creator added a custom script which doesn't follow the editor's standards. So when you unpack, the editor can only unpack the images. So after unpacking. The .json that you received there is no script that the creator added himself.
.json is the script that the program uses to create the watch face, not the script of the watch face that is used to run on the watch, so in this case if you need Study the function of the dial. You need to look at the index.js file which is in the .zip file.
Max88
asoo ha scritto: 22 gen 2024, 03:45
Ah ok, so it's quite more difficult than when I made wf for gts 2 mini :lol:
Thank you for help.
Just one thing, is there any guide to learn how to make wf now for zeppOs?
I don't know anything of that code, so I wouldn't know how to implement the necessary modifies or how to understand what I need.
Messaggio da asoo »
Max88 ha scritto: 22 gen 2024, 08:47
Thank you for help.
Script used in watchface is in javascript format.
So if you want to understand the script, you must study more about javascript
toolsrme
Hi @SashaCX75
I believe at one point I read a post somewhere in the forum that I believe was from you, but for the life of me I can't find it again. I could be wrong though, but just wanted to check.
Did you possibly mention a tool that you like that can convert the Zeppos special TGA images like what the Zeus CLI creates, back into valid PNG files?
BigBlind68
Messaggio da BigBlind68 »
toolsrme ha scritto: 29 gen 2024, 02:29
Hi @SashaCX75
You mean this tool? viewtopic.php?p=15464&hilit=ImageToZeppOS#p15457
toolsrme
Hi @BigBlind68
Thanks, but I don't believe so. That tool looks like it is for creating targa images that are used on the watch.
What I'm looking for is a tool that converts the ZeppOs targa file (even though it has a png extension) back to the original PNG format.
If I have it backwards though just let me know.
The post I remember had SashaCX75 mentioning something along the lines of "here is the tool I prefer". Tried multiple combinations in the search, but still couldn't find it.
toolsrme ha scritto: 29 gen 2024, 13:47
The link is just a utility that can convert images from watch face to normal png (it can convert images both ways).
There is also a "[TBUI] Watch face tool". It is designed for other types of watch faces, but it can also extract images from ZepOS watch faces as well.
I don't know of any other image conversion software.
PS. Updated the version of the utility at the link.
Max88
@SashaCX75
I have a question about your tool. I have bought an amazfit active (it arrives tomorrow, so I can't still test). I was wondering about the conversion function which your tool offers.
If I have understood corretcly, I can convert watchface from Gts 4 to Active. Am I right?
Maybe it's a stupid question, but it would be the first time for me using your tool (in general), so I have never tried this option in particular.
Thanks Sasha :)
@Max88
Not all watch faces can be unpacked. Therefore, not all watch faces can be converted.
These watches have different aspect ratios. When converting, the aspect ratio does not change, the watch face is simply scaled in width.
Max88
SashaCX75 ha scritto: 30 gen 2024, 17:13
@Max88
Ok, thanks for info. At least now I know it should work.
I'll test it once I'll have the watch. Thanks ^^
TRK88PL
Has thanked: 67 times
Been thanked: 40 times
Messaggio da TRK88PL »
Hey, @SashaCX75 when I convert original file from Gtr 3 pro to Gtr 4, then to Gtr 3 and example to Gtr Mini... There is a problem with position when align it's set to right, with every convert text or images move increasingly to the left... I don't have photo but...
This is correct
........ Right element
This is incorrect
... After few conversions
It's moving closer to left side by a few pixels... Can You somehow fix this? I use 10.2 editor version.
Thx.
Show the watch face where this error occurs.
If the offset is not large, it may be due to rounding when calculating the new image size. With each conversion this error may accumulate.
TRK88PL
Well I have only gtr 3, unfortunately so I can't show you how this looks on different watches, but You can check this https://amazfitwatchfaces.com/search/gtr/text/X-rot if You want, original file it's created on Gtr 3 pro and there is everything okay, but when You check Gtr 3 LD EN version then You will see a difference on watch, preview image it's from Balance / Gtr 3 pro but on other's models You will see a bug... And like You said it's bigger and bigger after another conversion.
slimak131
Messaggio da slimak131 »
Hello, thank you very much for the watch face editor program. I have two questions. Gtr4 3.0 stopped supporting the morning report shortcut, is there any way to fix it? That's why the program doesn't support AQI?
I will fix the launching of morning news in the next version (as far as possible).
I don't use AQI in the editor because I think this parameter is useless for many users. There is no information for which city it is displayed. For example, if you look at https://waqi.info/, the nearest point where I can see AQI is in a neighbouring city. And this result will be for all those who do not live in big cities. I don't see the point of looking up AQI in a neighbouring city.
slimak131
I understand, but now the program removes AQI from my shield. I have to add AQI manually every time after using the program. I live in a big city.
You can put the AQI widget code in a custom script (JS scripts section) and it will be automatically added to the watch face.
slimak131
Thank you very much, I will try this method.
Version 10.3
Mirror
slimak131
SashaCX75 ha scritto: 04 feb 2024, 09:48
It still doesn't work. Impossible, or maybe in the next version?
@slimak131
This version was already ready and I didn't want to make last minute changes.
You can replace 'MorningGreetingNewsScreen' with 'MorningGreetingCoverScreen' in the button function. It's not what it used to be, but the old version doesn't work now.
slimak131
Thank you, two of my problems fixed.👍
Torna a “Watchfaces tools”
