Messaggio da SashaCX75 »
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
shirumitsu
Messaggio da shirumitsu »
Sasha u can make this editor to mi band 5?
is very good!
shirumitsu
I have no plans to add support for other models.
I posted a link to the source code of the program. If the structure of the dials on the mi band 5 is similar, then perhaps someone will undertake to redo the program.
msz_trex
Messaggio da msz_trex »
hi guys.
this is a great tool, im having the time of my life right now designing the faces i always wanted to see.
one maybe exotic question:
is it possible to change the order in which the layers appear, e.g. have the hands be shown BELOW the digital time output? thank you.
msz_trex
jorgealmeida.rs
Messaggio da jorgealmeida.rs »
Good morning ! Are you going to make a new version including GTS 2, GTS 2e and GTS 2 MINI ?
jorgealmeida.rs
It is not possible to disassemble the GTR2 dials yet, so there are no custom dials. I am not aware of any progress in this direction.
lakshanhirumal
Messaggio da lakshanhirumal »
hi...Thanks alot for this program... im enjoying making many watch faces and uploading them to amazfaces app... Two issues found.......... when converting time into 12 - hour format..at the final outcome 12am still appears as 00:xx.... for ex. 12.15 am shown as 00.15 ... only 12:xx has the issue....
Secondly, whats the ideal resolution watch needs? 72? or 300? i find many watch faces getting a warning message while compiling that the file size exceeds 1.90mb... i've tried resizing images as much as i could...still no solution.. Please Help.
lakshanhirumal
These are clock software problems.
Only the size of the image in pixels is important. Pixels / inch doesn't matter.
szhabolcs
Messaggio da szhabolcs »
Hey there!
I am trying to make my first watch face. Everything seems fine in the application, and I checked my images, they seems alright.
I don't get any error messages nor a .log file which is strange.
Could you maybe check what could be wrong?
(GTR 42) https://we.tl/t-kyW6qF45n4
Thank you in advance!
ccolombo71
Messaggio da ccolombo71 »
SashaCX75 do you think there will be a version for GTS2 ?
szhabolcs
szhabolcs ha scritto: 23 dic 2020, 20:54
Hey there!
For everyone wondering, I made a folder inside the application under the C drive, which included a space
"C:\AmazFit_Watchface_Editor_(without_Python)_9_0\my faces\minimal_en\minimal_en.json"
changing to
"C:\AmazFit_Watchface_Editor_(without_Python)_9_0\my_faces\minimal_en\minimal_en.json"
solves the problem.
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Messaggio da demiurg1 »
Maybe not exactly on the subject, but I have a pretty important question.
Does anyone know if the GTR 2 watch faces in the form of BIN files are stored on the smartphone? If so, where? I will be grateful for your help.
demiurg1
As far as I know, GTR2 watch faces are stored in the same way as for GTR (First, you need to install one of the stock watch faces available in Amazfit (Zepp) /Android/data/com.huami.watch.hmwatchmanager/files/watch_skin_local /). But there are no tools yet that can work with these dials.
demiurg1
Thanks, I'll try. And has anyone tried BIN from GTR 47 to apply to GTR 2?
I have quite a lot of my own watch faces for the GTR 47 and I would like to use them or convert them to the GTR 2. Is it possible?
demiurg1
After loading the original BIN file (b3bb04012bea4e6c262b6192ca7f509a.bin) created for GTR 2 into the program "AmazFit_Watchface_Editor_ (bez_Python)" I only received the file "b3bb04012bea4e6c262b6192ca7f509a.log".
Contents of this file:
2020-12-25 12:33:51,076 - root - DEBUG - Opening watch face 'C:\programy\AmazFit_Watchface_Editor\Watch_face\b3bb04012bea4e6c262b6192ca7f509a.bin'
2020-12-25 12:33:51,076 - root - DEBUG - Reading parameters...
2020-12-25 12:33:51,076 - root - INFO - Reading header...
2020-12-25 12:33:51,076 - root - INFO - Header was read:
2020-12-25 12:33:51,091 - root - INFO - Signature: b'UIHH\x02\x00\xff', Unknown: 4294967168, ParametersSize: 16777723, isValid: False, deviceId: 64
2020-12-25 12:33:51,091 - root - DEBUG - Parsing parameters...
2020-12-25 12:33:51,091 - root - CRITICAL - 'Reader' object has no attribute '_parameters'
File "program.py", line 164, in parseResources
File "watchFaceParser\reader.py", line 13, in getParameters
AttributeError: 'Reader' object has no attribute '_parameters'
Anyone have any idea how to change this file so that I can edit or convert it?
I feel sorry for my watch faces, which I designed for the GTR 47. I would also like to have them in the GTR 2. Or maybe they can be converted in some way? If there is any other editor for GTR 2 watch faces, I would be grateful for the information.
B!GBOY
Messaggio da B!GBOY »
demiurg1 ha scritto: 25 dic 2020, 11:24
Yes they don't work as GTR2 has a different structure for the bin file. Unless someone reverse engineer it there won't be any custom watch faces for GTR2.
demiurg1 ha scritto: 25 dic 2020, 14:51
they don't even have the "HMDIAL" header as you can see in your error log.
NikiWafa
Messaggio da NikiWafa »
I tried to make animation on GTR42mm with version 7 .. after I installed it on my watch, my watch became hang and bootloop ... is the version above 7 still like that?
Been thanked: 2122 times
Messaggio da asoo »
NikiWafa ha scritto: 31 dic 2020, 22:30
I don't think about Version is a issue. The issue is likely caused by the size of the "BIN" file you created. It is larger than 1.5 m.
That I don't think so about the version in issue , because the program "pack and Unpack" part of the program remain the same until Current version
Currently the program is version 9.0. (01/01/2021) viewtopic.php?f=29&t=1076&start=425&sid ... 35e94e0629
NikiWafa
asoo ha scritto: 01 gen 2021, 01:52
thank you for the information, sorry if my language is messed up ... because I use google translate ;)
noender
Messaggio da noender »
Thanks for sharing this awesome application SashaCX75!
I wanted to ask a couple of questions:
-My main question is if its possible to reduce the file size by packing and compressing manually? Some people said this and I have the feeling that the auto-generated GIF file is taking way too much space.
-Is it possible to add function to specify width/height (scale) to images?
-If I add more PNG's to move (in another line) it doesn't work. But if I use the same PNG in more lines it does work. Meaning that I can animate one object multiple times, but not different objects.
Thank you!
macgd016
Messaggio da macgd016 »
Hi I'm new here so please treat me gently, particularly as I'm sure I am doing something stupid!
Having downloaded the editor and a simple watch face everything went well, the downloaded file unpacked and the editor showed all the elements, however, every attempts since fails.
I can see that the download file unpacks into the Watch_face folder but nothing appears in the editor. The exact sequence of events is;
download watchface file from amazfitwatchfaces DOT com/gtr/view/11299
set Path to the packer as
C:\AmazFit_Watchface_Editor_(without_Python)_9_0\Watch_face\project_53_packed_zip-294441-416547e75b.bin
Press Unpack compress bin
a windows File Manager pop up screen appears asking for the location of the bin file
select C:\AmazFit_Watchface_Editor_(without_Python)_9_0\Watch_face\project_53_packed_zip-294441-416547e75b.bin
file unpacks into Watch_face folder but noting further happens.
I've tried all sorts of things but I can't get past this point, I'm sure its something stupid I'm doing but need some help please
noender
1 No. Read the first post in this thread.
2 No, the size of the image depends on its size in pixels, there is no scale.
3 For animation of movement, you can add different images on different lines. There are dials where this animation works.
macgd016
Reset the settings. Do not change the path to the packer.
noender
Thanks SashaCX75. I'll do some more testing.
Regarding the use of "Movement between coordinates"- is it possible to animate without looping? Meaning, is it possible to stop the animation after running once?
PD
I just finished my first watch face with your program, it's already in the catalog named "KoF Kyo - Classic Arcade Collection I". Thanks!
NikiWafa
HI SashaCX75
is it possible or can it ?, if the WatcFace Editor added an altimeter?
thank you
Torna a “Watchfaces tools”
