py amazfit tool
afwafwafw
Been thanked: 14 times
py amazfit tool
Post by afwafwafw »
what is...
what isn't...
requirements
  • python3(tested on 3.7.4)
  • pillow(tested on 6.1.0)
## usage
* for verge lite
  * see scripts folder
    * to unpack
    * to pack
      * to pack
      * to unpack
* for GTR
  * to unpack
  * to pack
      * to pack
      * to unpack
rubiales41
Post by rubiales41 »
hello, how is it done, or where can I find the time points and minutes to make analog clocks ?, thank you very much
Has thanked: 128 times
Been thanked: 19 times
Post by taw_bip »
Does anyone have the Verge Lite JSON syntax?
I was looking to try and recreate one of the Bip watchfaces here but have not made much progress:
https://amazfitwatchfaces.com/bip/view/27822
Horatius80
Post by Horatius80 »
taw_bip wrote: 01 Mar 2020, 20:20
I think the Verge-LITE .json syntax is same as GTR47/42, T-Rex, GTS
lgsf
Post by lgsf »
Unfortunately, for most of the new watchfaces that are coming out recently on the GTR section, the tools is useless. I try to unpack many GTR 47mm sources and get all sorts of errors.
Is it being maintained and updated?
Maikeldevil
Been thanked: 44 times
Post by Maikeldevil »
I see in the PY code (Our tool to create our GTR watchfaces) there is worked on child parent base, i also see that the function dayprogress hasnt got its own element yet. I have a problem that i try to get this function dayprogress behind other elements, ideal would be behind the background.
Also in the background there we have a option to set the X and Y for this element but it doesnt work. When image is smaller then 454 x 454 on the gtr its shown in the left upper corner, if we could fix this i can fix my date problem. (rotating date behind clock).
Please help!
Shreyash75
Post by Shreyash75 »
can anybody please make a video on how to make custom watch faces for verge lite on windows because its really hard to understand by reading these posts!
Post by taw_bip »
Shreyash75 wrote: 10 Apr 2020, 21:50
Jackall Digital has several Mi Band 4 watchface tutorials that show you the basic process that is similar for many of the newer Amazfit watches.
https://www.youtube.com/channel/UCx7v6C ... PsQ/videos
But the easiest way to learn is by doing. Download some watchfaces and load them into SashaCX75's GTR_WatchFace editor. For me, this was the biggest leap forward because the tool is "one stop shopping" -- it unpacks several watchface types (GTR, GTS, Verge Lite) and loads them into the GUI tool, then it packs them when you're done.
viewtopic.php?p=5011#p5011
Make some changes to the JSON file, take notes on how certain features appear on the dial.
You will also need to learn how to use an image editing program like Photoshop or Adobe XD to make the graphics.
I've modified several existing watchfaces to convert them to 12 hour time format and added some icons.
It takes a little while to develop an understanding and a workflow.
Kivan
Post by Kivan »
Well, any news on how to decompile the new gts2/zepp square bins?
I have some bins from my new zepp square, but could not decompile them.
Maybe they are signed? 😱
hugeyangjing
Post by hugeyangjing »
@afwafwafw Huami GTR2 has been out for a long time, but the website still has no third-party dial. When will GTR2 be supported? Is there any plan to support this model?
B!GBOY
Post by B!GBOY »
hugeyangjing wrote: 24 Nov 2020, 01:10
Sadly there doesn't even seem to be someone with the required knowledge who is interested in investing/wasting time on GTR2. I bought the GTR2 because I saw there is a section for it here "GTR/GTR2" before finding out that none of the watchfaces work on GTR2 :(
afwafwafw
Post by afwafwafw »
Sorry guys. I don't own GTS2 and have no interest without real one.
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Post by demiurg1 »
Does anyone know if the GTR 2 watch faces in the form of BIN files are stored on the smartphone? If so, where?
eliasf
Post by eliasf »
demiurg1 wrote: 25 Dec 2020, 07:32
Have you found an answer for this question as I wanted the same?
demiurg1
Post by demiurg1 »
Yes, I found it myself. I experimented.
Standard dials (provided by the company) are stored in the directory smartphone: This computer \ Galaxy S20 Ultra 5G \ Phone \ Android \ data \ com.huami.watch.hmwatchmanager \ files \ watch_skin_local \ 64.
Watch faces designed by you are not necessarily stored on your smartphone, but you can download them to any (preferably self-created) directory and load them onto your watch using the Android application "Notify for Amazfit".
eliasf
Post by eliasf »
demiurg1 wrote: 02 Feb 2021, 16:38
Thanks for your answer, agreed I knew about the default Zepp directory, and the way to send TO the watch through Notify.
Still doesn't mean I can reverse the process somehow and get the bin FROM the watch.
For example I uploaded a watchface which has since been deleted and it is now only stored on the watch.
No way to get the .bin back? (to the phone or pc)
demiurg1
Post by demiurg1 »
I do not know such a method, so I will not help. If I come up with an idea, I will write it.
demiurg1
Post by demiurg1 »
Does anyone know how to make a watch face for GTR 2 so that when loading a BIN file to the watch, its preview appears, not a black watch face?
demiurg1
Post by demiurg1 »
I will specify the problem once again.
How to auto-generate GIF for GTR 2?
I do not know if, and possibly how, you can somehow automatically generate an animated GIF file from a watch face design I made. I have all the PNG files, the "json" file, the BIN file, but I only have the watch face as a 306x306 static PNG file and 454x454.
I would like to have a GIF, but I don't really want to "sculpt" such a character.
Does anybody have an idea?
Isaías Santos
Post by Isaías Santos »
manelto wrote: 22 Aug 2019, 17:45
Is It possible have this tool for GTR amazfit?
afwafwafw
Post by afwafwafw »
Isaías Santos wrote: 27 May 2021, 17:13
Maybe? I haven't test it for a while. But it worked for very first time. doesn't work for GTR2 though.
ninsei
Post by ninsei »
Hi. I'm a newbie and have looked around this forum but couldn't find a clear guide to get started modifying a watchface. I'm using and iphone and I have a GTS 3. There's a watchface I want to modify. Is there a walkthru for how to get that watchface from the iphone, onto my Windows machine, then modify the watchface, then upload that watchface to the GTS 3?
lobianco
Post by lobianco »
Hi, all
I'm new, and I'm trying to use this tool to generate a bin for the GTRmini model, can I use this tool?
If yes, what is the correct command?
If not, how do I do it?
Thank you very much
Has thanked: 414 times
Been thanked: 2071 times
lobianco wrote: 15 Jun 2024, 13:04
Hi, all
Thank you very much
This is a tool used to pack and unpack and edit watch faces that use ZeppOS as the operating system, which GTRmini is one of them.
PS. The format of the watch face using zeppOS will be .zip.
lobianco
Post by lobianco »
asoo wrote: 15 Jun 2024, 14:31
Hi, all
Thank you very much
lobianco
Post by lobianco »
lobianco wrote: 15 Jun 2024, 22:13
Hi, all
Thank you very much
Hi asoo,
I used the wonderful Watch Face Editor program (ZeppOS), as you indicated, from SashaCX75, I made a watchface for the GTRmini, it generated a .zip file, how do I install this watchface on the watch?
