py amazfit tool
afwafwafw
Been thanked: 14 times
py amazfit tool
Messaggio da afwafwafw »
what is...
what isn't...
requirements
  • python3(tested on 3.7.4)
  • pillow(tested on 6.1.0)
Codice: Seleziona tutto
## usage
* for verge lite
  * see scripts folder
    * to unpack
    * to pack
      * to pack
      * to unpack
* for GTR
  * to unpack
  * to pack
      * to pack
      * to unpack
TXK
Has thanked: 149 times
Been thanked: 97 times
Messaggio da TXK »
Can you make EXE programs?
afwafwafw
Sure but not right now.
You can generate it by executing auto-py-to-exe, though.
fx_advanc
Has thanked: 7 times
Messaggio da fx_advanc »
cool bro,
i have using it today, straight forward. but no animation.
afwafwafw
Yes, you're right.
It's a little trick but you can get animation .gif after unpacking packed_bin again.
i.e
python main.py WATCH_FACE.json # now you've got WATCH_FACE_packed.bin
python main.py WATCH_FACE_packed.bin # in WATCH_FACE_packed/ folder you can see gif file in there
侯侯大神
Messaggio da 侯侯大神 »
Why can't you use your tools to unpack your bin, only unpack the official ones
fx_advanc
I need to get the live editor, easier to locate the dial .png files to X & Y coordinate.
Do you have any guide tool for numbering x 1-360 x y 1-360 grid
AFWAFWAFW
afwafwafw
侯侯大神 ha scritto: 22 ago 2019, 04:13
I always use mine to pack/unpack my .bin.
Have you tried latest version of my tool?
Which bin cause issue for you? Can you give me a link for it?
afwafwafw
fx_advanc ha scritto: 22 ago 2019, 08:41
AFWAFWAFW
Hi. I'm using GIMP as a guide tool. :)
侯侯大神
Messaggio da 侯侯大神 »
Thanks for replying, friend, I should not be using the latest version
manelto
Messaggio da manelto »
Is It possible have this tool for GTR amazfit?
afwafwafw
manelto ha scritto: 22 ago 2019, 17:45
As I don't have a GTR watch, I cannot make the tool for GTR easily. There's one person who forked mine. He've changed the name as amazfit_gtr_tools so you can wait for his work or Amazfit watchfaces tool(posting.php?mode=quote&f=26&p=2400).
Ultima modifica di afwafwafw il 23 ago 2019, 05:21, modificato 1 volta in totale.
afwafwafw
侯侯大神 ha scritto: 22 ago 2019, 11:02
No problem. If you have any issue, let me have .bin for debugging.
manelto
afwafwafw ha scritto: 22 ago 2019, 21:54
OK! Thank you.
The problem seems to be the resolution (360 vs 454) and the header (header.bin). But maybe there is something else (sure: D).
manelto
viewtopic.php?f=29&t=782&p=2423#p2423
fx_advanc
Does gimp shows the coordinate? what name of the features.
afwafwafw
fx_advanc ha scritto: 24 ago 2019, 14:53
https://docs.gimp.org/2.10/en/gimp-conc ... uides.html
Right?
fx_advanc
Can you help me position the dial, thanks [mention]afwafwafw[/mention]
here's the link " https://justbeamit.com/89pag
afwafwafw
here's corrected version for tick.zip
https://drive.google.com/open?id=1xT_ct ... ou1v-q5cXv
Just remember that let "CenterImage.X", "CenterImage.Y" equal to pin position of time hands.
By comparing it with original tick.json, you can see how to set position of hands.
fx_advanc
yep been trying, i tried to set EMC first,
tick.json i forgot where did i put the original file (i take it from verge).
afwafwafw
TXK ha scritto: 19 ago 2019, 02:02
https://github.com/ghtalpo/amazfit_verg ... ease/win32
see usage/for_windows_users section in readme.md
Ferodo
Messaggio da Ferodo »
afwafwafw ha scritto: 26 ago 2019, 13:23
Thank you so much :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
koolgao
Messaggio da koolgao »
buenos dias compañeros para cuando https://github.com/ghtalpo/amazfit_verg ... ease / win32 este podra empacar las esferas de 42 mm del gtr? para el gtr de 47 va de lujo pero para el de 42 no hace nada
glenan
Messaggio da glenan »
Hello
Is there any tuto how to use Amazfit GTR TOols 32b ?
Thanks.
Torna a “Watchfaces tools”
Visitano il forum: Nessuno e 22 ospiti
