Guydu91
Has thanked: 58 times
Post by Guydu91 »
asoo wrote: 28 Sep 2025, 18:14
marrud12 wrote: 28 Sep 2025, 16:18
On the watchface of my Active 2 NFC I have a field with compass (no matter whether numerical values or images). When I tap a button with <Compass empty>, this app doesn't work, either black screen or freezing compass. When I clear the field <compass> on the watchface, the app button works fine. Has somebody a idea how to solve this problem?
I don't have an Active 2 NFC, so I'm not sure if the issue is the same as the Bip6, but from what you described, the symptoms are similar.
You can check out this post. I hope it's helpful.
viewtopic.php?p=21156#p21156
Same problem on GTS4... :?
curtis66
Post by curtis66 »
Hello. I have heart problems, and the HRV value is important to me. When I like a face, I download it and edit it with your fantastic software to adapt it to my needs and language. I always add this HRV data. I'd like to be able to create a button and assign this HRV function to it. It's not currently available. I'd also like, in addition to the numerical HRV data, the option to assign an image to the status shown in the app. Would that be possible?
Thank you, and congratulations on creating and constantly updating this face editor.
@curtis66 There's a button to launch the HRV app in the editor.
It is not possible to set a set of images for HRV (such as for the pulse).
curtis66
Post by curtis66 »
Perfect. Thanks for responding. And can you assign HRV to a button?
Mkmck
Post by Mkmck »
Hey. How can I convert WF made in Watch Face Editor to .ZAB file to share it to official Zepp market?
Bresbres
Post by Bresbres »
i made a wathface with my own interpretation of an other user his watchface. How can i upload that picture to my profile, but i don't want anyone else too see it already, cause it is still in development. but i want to upload it so i can download from amazwatchfaces to my BIP 6 to test it.
Or is there another way to upload a custom made watchface to my BIP 6, other than with amazfitwatcfaces?
Been thanked: 2122 times
Bresbres wrote: 09 Oct 2025, 13:24
You can try the link below, it might help you.
Emiliomc
Post by Emiliomc »
I created a watchface for my Balance 2 in SashaCX75's app. I created "Hours" and "Minutes" using the utility offered by the app. That is, without creating the .pngs. I just added the font I wanted the app to use. With horizontal alignment set to "Center". Vertical alignment set to "Top". Text wrap set to "Single line". I have "Add leading zeros" checked. In App Settings, I have unchecked the option "If possible, display the time in 12-hour format". I have AM/Pm checked with two .pngs of "Am" and "Pm". In the zip file that is generated when I package, I open the "watchface" folder and modify the two lines where it says "Am" and the two lines where it says "Pm", deleting "Am" and "Pm". Currently, when I have the clock set to 24-hour time, neither "Am" nor "Pm" appear. As it should. And it appears with leading zeros. As it should. But I'd like for the clock to be displayed without leading zeros when I set it to 12-hour time, which is when the "Am" or "Pm" .png files appear correctly. I've been digging through the index.js file, but I don't know which line I should modify. Or if I should add a line and where. If you could help me, please.
@Emiliomc The checkbox in the settings “If possible, display the time in 12-hour format” only affects the preview display in the editor. It does not affect the display on the watch. It is unclear why and which lines you are deleting with the mention of ‘Am’ and “Pm.” I don't think this is necessary.
Do you want leading zeros to be displayed in the 24-hour format but not in the 12-hour format?
Then you need to find the time_update function. If you use the watch:minutes widget to display the time, then there will be a line
normal_HourMinStr = normal_HourMinStr.padStart(2, ‘0’);
Replace it with
if (timeFormat == 0) normal_HourMinStr = normal_HourMinStr.padStart(2, ‘0’);
And before that, add
const timeFormat = hmSetting.getTimeFormat();
I haven't tested this code, but it should work.
Emiliomc
Post by Emiliomc »
It's obvious I'm doing something wrong, because it's not working for me. I'm including screenshots of the index.js file and the lines I think I understood, which I need to change. And screenshots of the app. When I select the 12-hour format on the clock, the leading zeros still appear. For example, 18:45 in 24-hour format, and 06:45 in 12-hour format. What I want is 00:45 in 24-hour format and 0:45 in 12-hour format.
@Emiliomc
I made a slight mistake. The condition should be as follows:
if (timeFormat != 0) normal_HourMinStr = normal_HourMinStr.padStart(2, '0');
Here is a test watch face with a code.
Test.zip
(135.64 KiB) Downloaded 90 times
Emiliomc
Post by Emiliomc »
Thank you so much, Sasha! The code works perfectly. Thanks so much!
Hieutr632
Post by Hieutr632 »
hello, can someone teach me how to convert gtr 4 watchfaces to amazfit balance?
Hieutr632 wrote: 16 Oct 2025, 16:15
What you need to know before converting a watchface:
1. The watchface file must contain a script that complies with the "Watchface Editor for Amazfit Watch on ZeppOS" standard.
2. The watchface file must not be encrypted.
If the watchface file contains encryption or scripts that do not comply with the program's standards, you will not be able to convert that watchface file.
If your watchface file does comply with the program's standards, the conversion process is as follows:
1. Prepare the .zip watchface file you want to convert.
2. Open the program and click "Unpack Watchface," then select the watchface file you prepared and click "Open."
3. Once the unpacking is complete, go to "Convert."
4. Select the Initial model that matches the original model and the Target model you want to process.
5. Click "Convert." When finished, click "OK."
6. Then click "Pack Watchface" to pack the converted watchface into a .zip watchface file.
Now you have a .zip watchface file converted to your desired device.
Preview
Emiliomc
Post by Emiliomc »
A few days ago, Sasha solved a problem I was having. I wanted the clock to have leading zeros when it was in 24-hour format. But when it was in 12-hour format, it wouldn't have leading zeros. The solution, which works perfectly, is to modify the index file. This corresponds to the first two screenshots I posted. The second screenshot is a modification of the first. But now I want to go further... I suspect, although I'm not sure, that it can be done by modifying the index.js file using code. As for code, I'm still below novice... but I'm trying. I would like the seconds to be located at a specific x coordinate (406) when the clock is in 24-hour format, and the seconds to be located at a different x coordinate (394) when the clock is in 12-hour format. The only thing I could think of is a "copy and paste". I copied the code for the seconds (third screenshot), added it to the solution Sasha gave me, but changed the x-coordinate value for the seconds from 406 to 394 (fourth screenshot)... and of course, it doesn't work. It wasn't going to be that simple, of course...
Emiliomc
Post by Emiliomc »
Okay, so far I think it was pretty bad. I should at least try it in console.log('second font'); and not in the hours and minutes. I've tried several ways in the seconds console. I think the key is != 0, but I've done several tests and it doesn't work.
@Emiliomc
What you wrote does not make sense. Such code can lead to endless creation of widgets and watch reboots due to insufficient memory. I recommend learning the basics of JS first.
Emiliomc
Post by Emiliomc »
Well, I tried to start completely from scratch and, without any help, make sense of something I've never studied in my life. Unfortunately, I don't have as much time as I suppose studying this language requires. For me, creating watchfaces is a hobby. I enjoy it when I'm not busy. I really appreciate both the warning and the recommendation, Sasha.
Has thanked: 130 times
Been thanked: 19 times
Post by taw_bip »
Emiliomc wrote: 26 Oct 2025, 21:50
I recommend using AI tools, such as ChatGPT or Claude or Gemini. Feed it your code and prompt it to make the modifications.
Post by taw_bip »
I install watchfaces from my Android phone this way:
1. download the file usually in .zip format (you can also install it across a network if the file is on a NAS)
2. clear the data/cache from the Zepp app
3. load the Notify for Amazfit app (you need to set it up, get your watch's pairing code, etc. follow the instructions)
4. when all set up, click on the "Devices" icon at the bottom. Tap "Watchfaces" press the "hamburger" settings icon on the top-left. Select "Custom watch-face (.bin)"
5. This will open up the phone file manager. If the file is in your Downloads folder, select that. Then select the .zip file. Hit the "Install" button.
6. If all goes right, it will install the watchface.
7. Once you're done testing, do the storage app/cache wipe of the Notify for Amazfit app.
8. Open the Zepp app and re-login to connect it to the watch.
Emiliomc
Post by Emiliomc »
Thank you
Emiliomc
Post by Emiliomc »
Sasha, is there a possibility that in a future update of your app, SashaCX75, you could add the ability to create a widget to view the smartphone's battery level on the smartwatch?
Displaying the phone's battery charge requires the installation of additional applications. Therefore, I am not sure whether it is worth adding such a feature to the watch face. After all, without these applications, it will not work.
Emiliomc
Post by Emiliomc »
Ok
Emiliomc
Post by Emiliomc »
I'm starting a new watchface project. It's analog. I had the idea that the watchface could display 12, 6, and 9 when the watch is in 24-hour mode. And when I select 12-hour mode on the watch, the face would display 12, 6, and 9 in the morning and 24, 18, and 21 in the evening. I've been researching whether this is possible directly in the SashaCX75 application, or if it requires modifying the index.js file, or if it's simply not possible. Currently, I have two identical watch faces, one with 12, 6, and 9, and the other with 24, 18, and 21. I've looked into Analog Time Pro, specifically activating "24-hour format" (which I don't understand), and adding the second watch face as a foreground image on the hour hand. I've also checked if the solution was in "Switchable Background." Ultimately, I don't know if this is possible at all.
