Regras do fórum
Avatar do usuário
Registrado em: 26 Out 2019, 15:18
Been thanked: 1044 times
Contato:
Mensagem por SashaCX75 »
Imagem
Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
Editado pela última vez por SashaCX75 em 01 Jun 2022, 07:19, em um total de 32 vezes.
murmilega
Registrado em: 23 Abr 2021, 22:19
Contato:
Mensagem por murmilega »
Hello everyone, could someone explain the process to convert or port a watch face from t-rex to t-rex pro? Thank you so much.
EDIT:
Thank you very much sasha, I had not seen the editor and sphere converter, thank you very much for your great work.
greetings
Avatar do usuário
Contato:
Version 4.0
demiurg1
Registrado em: 23 Fev 2020, 22:49
Has thanked: 23 times
Been thanked: 17 times
Contato:
Mensagem por demiurg1 »
There is already version 4.0 of the SashaCX75 editor, for which we thank you. I did my last project on version 3.1. The next one will be in the new version. This last project is my little experiment with a "cheated" animation in GTR 2. I made a pseudo-animation of a bird flying in front of a weather image. This is obviously 1 frames per second and only 10 frames. You can see this project here: https://amazfitwatchfaces.com/gtr/view/15399.
Anyone who wants to can modify it in their own way!
Fringo
Registrado em: 22 Mai 2020, 01:19
Contato:
Mensagem por Fringo »
Thank you for update! If you don't mind, I'd like to translate English into Korean(South)^-^
Jtkz
Registrado em: 11 Mai 2021, 15:56
Contato:
Mensagem por Jtkz »
Hi SashaCX75 ,
I recently made a wf for gtr2 but when I test it on the watch the second hand seems to skip every second and only moves once every 2 seconds. There also seems to be a delay in waking the watch by clicking the button when using this watch face. This wf is much simpler and also smaller compared to my other watch faces so I'm not sure why this is happening. May I know if I did anything wrong with this wf?
The wf is attached below.
Anexos
gtr2_junghans_maxbill_chrono full black_packed.bin
(221.98 KiB) Baixado 202 vezes
Avatar do usuário
Contato:
Fringo
I do not plan to add translations to the editor, it is difficult to keep up to date version for many translations. And in the Korean language, as far as I know, the length of the inscriptions is very different from other languages and will need to be edited a lot. If you work with Visual Studio, you can translate the editor yourself.
Avatar do usuário
Contato:
Jtkz
You have a very large images with pointers. You need to crop empty areas on them.
Jtkz
Contato:
Mensagem por Jtkz »
Do you mean the pointer images themselves are too large?
Avatar do usuário
Contato:
Jtkz
Yes. There is a lot of empty space on them.
Avatar do usuário
CASIONFAN2021
Registrado em: 16 Abr 2021, 21:23
Contato:
Mensagem por CASIONFAN2021 »
Thank you sasha for the update. Its fantastic to have sunrise sunset now. There is no way to loaf any values into the sunrise sunset other than to click random values. I have noticed that when this is done the random values for the same function are random I.e if you have a circle and pointer at the same time you have to click random values a lot to get them to line up with each other making it tedious to check if the start angle of the pointer and the beginning angle of a circle and the end angle of pointer and circle are the same. Will there be an update to the values section to add start and finish time off the sunrise sunset. While it's not essential it would make life less random.
Ps the atmosphere barometer on t rex pro doesn't work with watch face after loading barometer on watch.
spidercrab
Registrado em: 25 Jun 2020, 09:13
Has thanked: 27 times
Contato:
Mensagem por spidercrab »
@SashaCX75 Big thanks for the solid work on the new V4 editor. The new Rotated and Circle System text is a powerful new feature and well implemented.
Could I put in a furure request, to add access to more or all of the system fonts, if possible?
The current one is quite thin and there are some system fonts that look heavier and easier to read, such as the Workout Italic system font and the Timer font.
Using system fonts throughout a design could greatly simplify WF creation and also I assume, make a significant reduction in file size. (Assuming the system fonts are loaded directly from the WF firmware.)
Avatar do usuário
Contato:
CASIONFAN2021
The barometer does not work on the T-Rex Pro.
Sunrise and sunset times change every day depending on the city. Therefore, in the editor, I see no reason to customize it. In the editor, sunrise at 5:30 am and sunset at 7:30 pm. Progress is calculated based on the current time. But I do not recommend using progress. In addition to time, other display methods do not always work correctly.
Avatar do usuário
Contato:
spidercrab
The system font is in the firmware of the watch and cannot be changed using the dial.
gengtrex
Registrado em: 06 Fev 2021, 02:47
Contato:
Mensagem por gengtrex »
is it still possible to have an animation on trexpro someday, according to its system?
cos it is making me hesitate to buy a trexpro if it seems impossible for that.
(now i am happy with animation on my original trex.)
thanks. :)
Avatar do usuário
Reysonk
Registrado em: 03 Mai 2021, 11:03
Contato:
Mensagem por Reysonk »
@SashaCX75 look here tap zone! https://amazfitwatchfaces.com/t-rex/view/5875
Editado pela última vez por Reysonk em 07 Jun 2021, 19:53, em um total de 1 vez.
Avatar do usuário
Has thanked: 438 times
Been thanked: 2141 times
Contato:
Mensagem por asoo »
Reysonk escreveu: 07 Jun 2021, 19:52
That file BIN is not format T-rex pro. That BIN create by "AmazFit_Watchface_Editor_(GTR47ToGTR2)" or convert by "GTRtoGTR2" from T-rex , GTR , GTS
( you can see the program on the first post ) viewtopic.php?p=8392#p8392
if you unpack BIN and open the .json you will see the command line is a T-rex format. So BIN can use shortcuts.
You will notice that file convert by "GTRtoGTR2" or create by AmazFit_Watchface_Editor_(GTR47ToGTR2)" it doesn't have a custom AOD, and the weather icon has only 25 types + 1 icon "No data"
Avatar do usuário
Contato:
The size of the system font should not be more than 47, it can cause an infinite reboot watch.
vaibhthakur
Registrado em: 10 Abr 2021, 09:31
Contato:
Mensagem por vaibhthakur »
Hello, is it possible to add the imagescount tab in the GTR2 software? I am trying to port a watchface from GTR 47 mm using the convertor and using the converted png image files to develop a watchface for gtr2 from scratch. Due to the unavailability of imagescount, it is taking in the values from the next pngs. Please tell me if there is a fix for this at the moment. Thanks in advance!
Avatar do usuário
Contato:
vaibhthakur
I don't understand why the "imagescount" tab is needed. All elements that allow you to change the number of images have such a parameter. In this version of the editor, it is called "Number of images"
vaibhthakur
Contato:
SashaCX75 escreveu: 13 Jun 2021, 19:13
@vaibhthakur
Okay got it! Thanks. The GTR2 has more weather icons so it took more values. I added them and it was good to go
AlexS85
Registrado em: 11 Jun 2021, 21:51
Contato:
Mensagem por AlexS85 »
Возникла такая проблема: загружаю изображения в первой вкладке, но дальше во вкладке "Редактирование" программа не дает выбрать загруженные изображения :(
Avatar do usuário
Contato:
alex585
Количество загруженных изображений должно быть не менее 3.
Avatar do usuário
Contato:
Version 4.1
demiurg1
Contato:
SUPER :)
sfreud
Registrado em: 07 Ago 2020, 06:49
Contato:
Mensagem por sfreud »
u can make it reverse when u can...gtr2 to 47/42 ,iamiam :D
Responder
Quem está online
Usuários navegando neste fórum: Nenhum usuário registrado e 2 visitantes
