- Amministratore
Is any step by step Guide how to protect your watchfaces?
g-rex69
- Has thanked: 4 times
- Been thanked: 2 times
- Contatta:
Im using Watch Face Editor (ZeppOS), is there any option to protect the zip file before pressing "pack watch face"?
i have few more questions:
1. Can you supply a step by step guide how to protect the "js" folder, pictures etc...
2. if converting the zip to bin protects the watchface on a certain level?
What can u recommend?
Thanks.
Thanks.
- frankh93
- Has thanked: 20 times
- Been thanked: 3 times
- Contatta:
As far as I know, there isn't a way to protect your watchfaces more than "uglify" the index.js but still anyone can have access to the images and replicate the design if they are skilled enough
you should be doing something productive instead of reading this caption
g-rex69
- Contatta:
can you refer me to a guide how to use "uglify"?frankh93 ha scritto: 15 mar 2026, 16:37As far as I know, there isn't a way to protect your watchfaces more than "uglify" the index.js but still anyone can have access to the images and replicate the design if they are skilled enough
- Has thanked: 405 times
- Been thanked: 2028 times
If you want to 'uglify' JavaScript, I recommend checking out:
https://github.com/mishoo/UglifyJS
The website provides step-by-step instructions on usage and installation.
However, if excessive uglifiy with index.js might that index.js will not run on device normally.
The command line I've used to "uglify" the index.js and still get tworking on the device normally is:
Codice: Seleziona tutto
uglifyjs index.js -m -c -o index.js
MarioLie
- Has thanked: 40 times
- Been thanked: 24 times
- Contatta:
The user still does not understand that there is no way to prevent someone who purchases his work from passing it on for free to another user. And even encrypted works can be copied. Perhaps it would be better to always create one's own works and either offer them freely or for a fee, knowing that it will make someone happy. The best approach is to create works directly for individuals, and those are then not copied.
g-rex69
- Contatta:
i have tried "uglify" and i didnt understand yet how to work with it. i will try again. MarioLie, i do understand, as a watchface builder perspective, and im talking about my self in this case. im working hours on my watchfaces, thinking about ideas how to build new watchfaces. its not come easy. specially the JS programing(im not a programmer). it will be much easier for me to give them for free if i could protect them better. anyway, i appreciate the reply.
g-rex69
- Contatta:
What is the "index.js"?asoo ha scritto: 16 mar 2026, 08:31If you want to 'uglify' JavaScript, I recommend checking out:
are u talking about the prime "json" file in the root folder or the files inside the JS folder.
so i understand i need to use the UglifyJS before im packing a watchface to zip file
"index.js" is not included in the project's boundary package.g-rex69 ha scritto: 17 mar 2026, 08:24What is the "index.js"?
To implement UglifyJS, you need to work with the index.js file. This file is located in the watchface .zip file that you received after unzipping. After unzipping, you will see index.js in the watchface folder. Then, unglify that index.js file and place it back in the same .zip file. In short, Uglify is do on the index.js file located within the watchface (.zip) file.
It's not done during project creation. You must first create the watchface file to obtain the .zip file, then unzip and Uglify the index.js file that inside the .zip and zip it into its original location.
Visitano il forum: Nessuno e 5 ospiti
