Been thanked: 1044 times
v18.1
Version 18.1
Has thanked: 438 times
Been thanked: 2142 times
rush2112 wrote: 15 Sep 2025, 08:31
@asoo
I'm not entirely sure about your question. From the image you attached, it look like you wath to enable a shortcut on the image of the element that supports this functionality.
if I think right , the method of use is simply to place the correct mark in the frame, and then the heart reate image (Zone) will be a shortcut link to that element. ( in this case shortcut is open heart rate screen )
That's it, nothing more.
x: 162,
y: 29,
image_array: ["Act_W_0.png", "Act_W_1.png", "Act_W_2.png", "Act_W_3.png", "Act_W_4.png", "Act_W_5.png"],
image_length: 6,
shortcut: true,  <----------------- This is the line that sets the heart rate image as a shortcut. ------------
type: hmUI.data_type.HEART,
It works the same as the shoutcut element.
normal_heart_jumpable_img_click = hmUI.createWidget(hmUI.widget.IMG_CLICK, {
x: 151,
y: 334,
w: 100,
h: 100,
The only difference is that you can't specify x, y, w, or h.
The " shortcut: true " is attached to the element's image.
Actually, if you want to understand more, try creating a widget
and pack it in. Then, look at index.js. or sync to you watch for test.
You should be able to understand it better.
rush2112
Has thanked: 121 times
Post by rush2112 »
Thanks for your help.
@rush2112 If you use this widget, turning on this switch allows it to function as a shortcut. Nothing else needs to be added.
Emiliomc
Post by Emiliomc »
Maybe I didn't search properly, and I apologize. I've updated to the latest version of sashacx75's app (Version 14.1.1) and once installed, I can't get it to run despite the initial warning when trying to run it. The app simply won't open. I've deleted and re-downloaded it, but nothing. I've given it permissions on my firewall, but nothing. I've tried running it as an administrator, but nothing. I have an updated Windows 11. What am I doing wrong?
Emiliomc wrote: 15 Sep 2025, 14:40
Please try this Version 15
viewtopic.php?p=21105#p21105
Emiliomc
Post by Emiliomc »
Thank you so much!!! I was trembling for a moment, because the previous version wasn't working for me either. Thank you, thank you, thank you.
Version 15.1
UlliT.
Post by UlliT. »
is it normal, that the watch face editor cannot maximized and has no save button (only save as)?#
And where do i find help how to install my watchface on my amazfit active 2?
(there is a link to a how to - but this is only for android 10 and older)
Ulli
The editor window cannot be enlarged, and this will not change in the near future.
The editor will prompt you to save the project when you exit or compile the watch face. You can also save it by pressing Ctrl+S.
viewtopic.php?t=3873
The installation method does not depend on the Android version.
UlliT.
Post by UlliT. »
(hope, that this is not a duplicate - i did not find the last attempt...)
Thanks for your help - so i could install my first own watchface on my amazfit active 2.
I am happy that (in contrast to the Zepp Editor) the altitude and the sensor-temperatur are possible and working.
But there are two issues:
1. The position of texts are on the watch not at the exact the same as in the watchface editor.
2. In the Editor i have a battery bar and a step goal bar. Both are made exactly on the same war. But only the battery bar comes to the watch.
it is easy to change the position of texts in the editor, so that it looks better on the watch.
But i have no idea about the missing bar...
Any ideas?
@UlliT. It all depends on how these elements are made.
If the numbers are an external font, unfortunately for many fonts, the text position does not match what is in the editor. I can't do anything about this, so there is a warning in the font settings to check how they look on the watch.
If the progress scale for steps is made as a set of images, they will not start displaying from step 1. It depends on the number of images used and the purpose of the steps. Usually, 400 steps are needed, and this can be seen in the editor.
UlliT.
Post by UlliT. »
@SashaCX75
Thank you very much for the explanations. ...
But: The font for hour and minute is one of the fonts coming with your editor. And also the hour and minute is not at the "correct" position.
No fonts are included with the editor.
Has thanked: 134 times
Been thanked: 21 times
Post by taw_bip »
@SashaCX75 Will the editor update automatically if installed from the Microsoft store?
@taw_bip I think it depends on your stored settings. It also depends on how you installed the application, whether from the store application or from the store website.
lobianco
Post by lobianco »
I'm creating a watchface for the GTR mini using SachaCX75's extraordinary program. When I click the button I created to call the user_js function, which changes the background, clock hands, and battery color (created using Circle Progress, in white), everything changes as desired. However, when the smartwatch turns off the screen and then displays the screen again, the background and clock hands continue to change, as desired by clicking the button, but the battery circle color returns to white, not the color I intended by clicking the button.
Where am I going wrong?
user_functions.js
(2.34 KiB) Downloaded 149 times
lobianco wrote: 21 Sep 2025, 14:58
You'll notice in index.js that the Battery Circle Progress widget is updated via the scale_call() { ....................} function.
And the scale_call() function will be Processing again with function "resume_call" after screen open
So, when the screen goes off and back on, or the battery value changes, the color of the Circle Progress will be updated with the value in the scale_call() function.
function scale_call() {
console.log('scale_call()');
console.log('update scales BATTERY');
let valueBattery = battery.current;
let targetBattery = 100;
let progressBattery = valueBattery/targetBattery;
if (progressBattery > 1) progressBattery = 1;
let progress_cs_normal_battery = progressBattery;
// normal_battery_circle_scale_circle_scale
let level = Math.round(progress_cs_normal_battery * 100);
if (normal_battery_circle_scale) {
////// battery circle porgress will be update with this line script
center_x: 240,
center_y: 240,
start_angle: 0,
end_angle: 360,
radius: 98,
line_width: 5,
corner_flag: 0,
// change color code with Variable values ​​in this line
color: 0xFFFF8C00,
level: level,
resume_call: (function () {
console.log('resume_call()');
scale_call();
//dynamic modify end
So, even if you change the color with your script, when the screen goes off and back on, or the battery value changes, the color of the battery circle progress will be the color specified in scale_call().
So, if you want to change the color that you plan, After you've packaged you must to edit it in index.js direct.
You can set the color value in a variable and replace it in "color:" line
Edit your user_functions.js :
let colornumber_main = 1
let totalcolors_main = 7
let colors = "0xFFFFFFFF"
function click_Color() {
        colornumber_main=1;
    else {
    if(colornumber_main==1) {
               colors = "0xFFC9C9C9"
        else {
            if(colornumber_main==2) {
                colors = "0xFFFFCC00"
            else {
                if(colornumber_main==3) {
                    colors = "0xFFBAC095"
                else {
                    if(colornumber_main==4) {
                        colors = "0xFFFFB3BA"
                    else {
                        if(colornumber_main==5) {
                           colors = "0xFFBAE1FF"
                        else {
                            if(colornumber_main==6) {
                                colors = "0xFFFF9224"
                            else {
                                if(colornumber_main==7) {
                                    colors = "0xFFFF0000"
For example:
Edit Widget and function scale_call() in file index.js :
// in widget area
           normal_battery_circle_scale = hmUI.createWidget(hmUI.widget.ARC_PROGRESS, {
              center_x: 240,
              center_y: 240,
              start_angle: 0,
              end_angle: 360,
              radius: 98,
              line_width: 5,
              corner_flag: 0,
              color: colors,
// in  scale_call() area
center_x: 240,
center_y: 240,
start_angle: 0,
end_angle: 360,
radius: 98,
line_width: 5,
corner_flag: 0,
color: colors,
level: level,
However, this is not the only solution. There may be many other solutions, depending on individual perspectives.
Version 15.1
Archive
Installer
Phantan74
Post by Phantan74 »
I use "Watch face editor for Amazfit watch on ZeppOS" to create a watch face for Active 2. I want the battery hand to point from 0 to 100 (see attached image) but in fact it goes beyond the range from 0-100.
Please help me. Thank you very much.
https://1drv.ms/i/c/52a6f8787c10ee6a/EZ ... Q?e=Q7zCxM
https://www.dropbox.com/scl/fi/0jclass0 ... ls6p3&dl=0
Lattenknaller
Has thanked: 62 times
Been thanked: 168 times
Post by Lattenknaller »
start angle -120
end angle 60
Phantan74
Post by Phantan74 »
Lattenknaller wrote: 25 Sep 2025, 08:24
start angle -120
end angle 60
Thanks, how to get this -120/60 value?.
Phantan74 wrote: 25 Sep 2025, 08:50
start angle -120
end angle 60
This is obtained by calculating the degrees of a circle.
If the degrees are positive, it's easier to understand.
Start at 240
End at 420
The result is the same.
360 + (-120) = 240
360 + (60) = 420
However, in some cases, using a degree value greater than -+360 may cause problems with calculations in some widgets, so the value - is used instead.
Phantan74
Post by Phantan74 »
asoo wrote: 25 Sep 2025, 10:38
start angle -120
end angle 60
Start at 240
End at 420
360 + (-120) = 240
360 + (60) = 420
i understand, thank you very much
marrud12
Post by marrud12 »
On the watchface of my Active 2 NFC I have a field with compass (no matter whether numerical values or images). When I tap a button with <Compass empty>, this app doesn't work, either black screen or freezing compass. When I clear the field <compass> on the watchface, the app button works fine. Has somebody a idea how to solve this problem?
marrud12 wrote: 28 Sep 2025, 16:18
I don't have an Active 2 NFC, so I'm not sure if the issue is the same as the Bip6, but from what you described, the symptoms are similar.
You can check out this post. I hope it's helpful.
viewtopic.php?p=21156#p21156
