Been thanked: 1029 times
Zecodorna wrote: 12 Apr 2025, 03:42
What is the url to add a shortcut to the training history screen?...
hmApp.startApp({url: 'SportRecordListScreen', native: true });
hmApp.startApp({url: 'SportScreen', native: true });
There are buttons like this in the editor.
Zecodorna
Post by Zecodorna »
SashaCX75 wrote: 12 Apr 2025, 07:09
There is already an image in the background of the display...is it possible to make the button transparent?...
@Zecodorna Set a transparent image on the button
gingerbeardman
Been thanked: 11 times
Post by gingerbeardman »
Is it possible to set alignment "Primary-secondary Relationship: follow" like in watchface website?
Does anybody use that?
Has thanked: 414 times
Been thanked: 2073 times
gingerbeardman wrote: 13 Apr 2025, 21:32
I'm not sure if I understand correctly
In the editor, there is a section that works similar to watchfaceMaker
In Digital time,
in the minute section, there is a selection [ ] Follow the hour
And in the seconds section, there is a selection [ ] Follow the minute
And in the Date section, if you want to display it as numbers, there is something similar to what you want
You can choose "Day/Month/year by font"
I hope my answer is what you asked.
gingerbeardman
Thanks I'll try it.
Ideally I want to do it on things other than hours and minutes. Like date and day.
I'll check my app is the latest version.
I'm using Amazfit Band 7, zepp os 1.0, so I think I can't use TTF font only system font? I'm happy to be wrong about this.
conan777
Post by conan777 »
SashaCX75 wrote: 10 Apr 2025, 17:15
Francko76 wrote: 10 Apr 2025, 08:41
thanks a lot sasha, but how to test the wf?
If you are asking how to install a watch face on a watch, here are the instructions
viewtopic.php?t=3873
Hello, I've followed the steps to install a watchface on my BIP 6, having done it for a GTS4, and it works fine, but I can't get the buttons to work. Is there anything special that needs to be done differently with previous versions of the program? I followed the same steps as I did previously for the BIP 5, but it doesn't work.
conan777 wrote: 15 Apr 2025, 08:57
If you want to check the problem like this, it is best to send the file that you have the problem with. Because if you don't send the file, I guess that those who want to help you will not be able to answer the problem.
And if possible, please open a new thread with a topic related to the issue you are having with the watchface you created.
As far as I tested, the 13.1 program can create Bip6 faces, including shortcuts and buttons, correctly.Just pack it as GTS4 and it can be used with Bip6.
So if the face file you created has the problem as you reported, I would recommend attaching the file you are having trouble with so that those who want to help can check it to find the error.
The button and shortcut section, as far as I have tested. There is nothing new. in the last beta still do that same as 13.1 in all respects.
conan777
Post by conan777 »
Thank you very much, I see that it works now, I'm making another one and I hope that when I finish it I'll also manage to get it working.
conan777
Post by conan777 »
Asso, could you send me the sphere files so I can save it?
conan777 wrote: 15 Apr 2025, 14:17
If you mean the watchface's file I edited in the thread you asked about, you can found link download is under the QR-Code.
viewtopic.php?p=20319#p20319
Why don't you ask in the topic that you opened?
This question it not about the editor at all. If you still ask about your watchface issue in Editor Topic , I won't answer. Becuase It makes the topic confusing.
conan777
Post by conan777 »
Sorry, when I hit reply I thought I was in the topic I had started, I hadn't realized.
EmaPolice
Post by EmaPolice »
Hi, how to unpack whatchface from zepp store?
https://mmk.pw/en/zepp_explorer/6553856/141750/
EmaPolice wrote: 15 Apr 2025, 21:49
The editor cannot unpack correct the watchface file that encode.
When you unpack watchface file that encode.
You will only receive the images used to create the watchface.
You must use the images to create a new watchface by yourself.
The watchface you mentioned in the link is a watchface that is encoded in a script, so as far as I know you can only do what I said.
Emiliomc
Post by Emiliomc »
Hi, I'm trying to figure out if it's possible to do something with a watchface on my Amazfit GTS 4 device using SashaCX7's app. The GTS 4's screen can be turned on by pressing the crown button or by raising my arm. I'd like to have the option (which the GTS 4's settings don't offer) to turn the screen on by tapping the screen, like a smartband. I thought about creating a watchface with a black AOD and setting the GTS to "Always On." I also wanted to add a button to the AOD (which the app doesn't allow) that would turn the screen on when clicked. Also, there's no such option to add a button.
Do you have any ideas for how to do what I want?
@Emiliomc You can try to add a listener for the image instead of the button. But I think it will not help. Most likely gesture tracking in AOD mode is disabled at the firmware level.
https://docs.zepp.com/docs/1.0/referenc ... tListener/
Emiliomc
Post by Emiliomc »
Thanks. I'll try it when I can. Although it's probably what you're saying... That it's not possible. A few days ago I contacted Zepp requesting an update regarding the screen turning on via touch, but they most likely won't respond and won't update it. I'll try your suggestion. See if I have any luck.
C2M
Post by C2M »
Hi all,
I'm getting the following error while trying to pack a watch face in the editor. I get the same error when generating a gif.
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index.
When I click on Details I get the following message:
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
   at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
   at Watch_Face_Editor.Form1.IMG_NUMBER_Year_Options(hmUI_widget_IMG_NUMBER img_number_year, String show_level, Int32 tabOffset)
   at Watch_Face_Editor.Form1.AddElementToJS(Object element, String show_level, String& variables, String& items, String& scale_update_function, String& resume_call, String& pause_call, String& time_update, String& text_update, String& fonts_cache, String& compass_update, String& compass_error, String& weather_few_days, String& weather_few_days_end)
   at Watch_Face_Editor.Form1.JsonToJS(String& variables, String& items)
   at Watch_Face_Editor.Form1.button_pack_zip_Click(Object sender, EventArgs e)
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.9300.0 built by: NET481REL1LAST_C
Watch_Face_Editor_(ZeppOS)
    Assembly Version: 13.1.0.0
    Win32 Version: 13.1.0.0
    CodeBase: file:///C:/XXX/Watchface%20Editor/Watch_Face_Editor_(ZeppOS).exe
    Win32 Version: 4.8.9251.0 built by: NET481REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 4.8.9282.0 built by: NET481REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 4.8.9037.0 built by: NET481REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Newtonsoft.Json
    Assembly Version: 13.0.0.0
    Win32 Version: 13.0.3.27908
    CodeBase: file:///C:/XXX/Watchface%20Editor/Libs/Newtonsoft.Json.DLL
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
    Win32 Version: 4.8.9297.0 built by: NET481REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Numerics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Runtime.Serialization
    Win32 Version: 4.8.9241.0 built by: NET481REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Data
    Win32 Version: 4.8.9214.0 built by: NET481REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
ControlLibrary
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/XXX/Watchface%20Editor/Libs/ControlLibrary.DLL
ControlLibrary.resources
    CodeBase: file:///C:/XXX/Watchface%20Editor/Language/en/ControlLibrary.resources.DLL
Watch_Face_Editor_(ZeppOS).resources
    CodeBase: file:///C:/XXX/Watchface%20Editor/Language/en/Watch_Face_Editor_(ZeppOS).resources.DLL
Magick.NET-Q16-AnyCPU
    Assembly Version: 7.17.0.0
    Win32 Version: 7.17.0.1
    CodeBase: file:///C:/XXX/Watchface%20Editor/Libs/Magick.NET-Q16-AnyCPU.DLL
DotNetZip
    Assembly Version: 1.16.0.0
    Win32 Version: 1.16.0
    CodeBase: file:///C:/XXX/Watchface%20Editor/Libs/DotNetZip.DLL
enabled.
For example:
<configuration>
</configuration>
If I click on continue the packing never finishes and no zip file is created.
Any idea what could be the cause of this?
Thanks a lot
@C2M Send the project in which the error occurs so that we can investigate it.
C2M
Post by C2M »
Here it is (heavily inspired by Distant Peaks from Avoska1988).
Thank you for your help!
Project.zip
(897.75 KiB) Downloaded 124 times
@C2M You have elements on your AOD that refer to the image ‘temp_0’ which does not exist. Fix it.
C2M
Post by C2M »
This fixed it. I don't use AOD so I completely forgot about it... Rookie mistake.
Thanks a lot!
gingerbeardman
(Also mentioned on Zepp Discord)
Interesting finding regarding zepp store distribution of watch faces created using this tool.
- I built a watch face with this tool
- I submitted it to Zepp using Zeus cli
- It was approved and has had thousands of downloads in the past couple of weeks
- Today, it was removed/unapproved because the exported code uses Logger.
changes
- Easy 4 line change (one logger include/define, three logger calls)
- Version number bump, to fix error "The installation package version is too low"
- `zeus build` and reupload
so
- Maybe the watch face app can be updated to include this change?
- Maybe Zepp system could replace Logger with console.log automatically?
[Zepp Open Platform] watch face approval failed
Dear developer:
The watch face DIN you submitted has not been approved due to the following reasons:
Reason for Removal: The current watch face uses the Logger module, which may be unavailable in certain system environments, potentially causing the watch face to fail to load.
Suggested Fix: Please replace all instances of Logger in the source code with console.log to enhance compatibility and ensure proper loading. Once updated, you may resubmit it for review.
. Please understand and resubmit the watch face access request.
@gingerbeardman I replied to you on Discord. I will briefly tell you here as well.
In the code generated by the editor, console is used. Logger is used only in the unchangeable part of the code, which is copied from official watch faces. That's why I don't understand such a requirement.
killmeplsok
Post by killmeplsok »
Hey, I just got a new watch 2 days ago and finds the official watch faces inadequate, and after some research I found this wonderful thread and tool to started working on my own watch face, it's been wonderful so far, but it's still a first time for me so I might be asking some stupid question (I have not been able to find related questions about this so far).
I was trying to work on a watch face that focuses on sleep tracking, so I was trying to get certain data such as BODY_TEMP and SLEEP working.
Based on my research on Zepp's documentation I might be able to rely on these 2 data:
hmSensor.id.SLEEP -> hmUI.data_type.SLEEP
hmSensor.id.BODY_TEMP -> hmUI.data_type.BODY_TEMP
But I couldn't find it anywhere on the tool's UI, am I missing something here?
