Help with color change on tap script
piotarock
- Has thanked: 15 times
Hello Devs,
I am trying to make a watchface with color change on tap option. Everything is working well apart from the pointer. I want the pointer to change color together with the background (bg_) as shown in the attached images. However, while background is changing, the pointer is not changing. It seems I am missing something. Any help or guidance is appreciated. Thank you.
Lattenknaller
- Has thanked: 60 times
- Been thanked: 146 times
Try this
pointer is not an img in the code, it must be treated differently
let colornumber_main = 1
let totalcolors_main = 5
let namecolor_main = ''
let pointerstring = 'pointer_1.png'
function click_ColorStyle() {
colornumber_main=1;
else {
if ( colornumber_main == 1) { namecolor_main = "Magnesium"
pointerstring = "pointer_" + parseInt(colornumber_main) + ".png"
if ( colornumber_main == 2) { namecolor_main = "Phosphorus"
if ( colornumber_main == 3) { namecolor_main = "Curium"
if ( colornumber_main == 4) { namecolor_main = "Thallium"
if ( colornumber_main == 5) { namecolor_main = "Cesium"
if ( colornumber_main <= 5) {
normal_battery_pointer_progress_img_pointer.setProperty(hmUI.prop.MORE, {
src: pointerstring,
center_x: 93,
center_y: 237,
x: 19,
y: 75,
start_angle: 0,
end_angle: 360,
type: hmUI.data_type.BATTERY,
hmUI.showToast({text: namecolor_main });
normal_calorie_icon_img.setProperty(hmUI.prop.SRC, "bg_" + parseInt(colornumber_main) + ".png");
- SashaCX75
- Has thanked: 14 times
- Been thanked: 1043 times
Changing properties with hmUI.prop.MORE is correct in this case. But I don't understand why to add an additional variable ‘pointerstring’? I would change the function like thisLattenknaller wrote: 14 Feb 2025, 07:47Try this
if (colornumber_main>=totalcolors_main) colornumber_main=1;
else colornumber_main=colornumber_main + 1;
if ( colornumber_main == 1) namecolor_main = "Magnesium";
if ( colornumber_main == 2) namecolor_main = "Phosphorus";
if ( colornumber_main == 3) namecolor_main = "Curium";
if ( colornumber_main == 4) namecolor_main = "Thallium";
if ( colornumber_main == 5) namecolor_main = "Cesium";
src: "pointer_" + parseInt(colornumber_main) + ".png",
center_x: 93,
center_y: 237,
x: 19,
y: 75,
start_angle: 0,
end_angle: 360,
