Been thanked: 1029 times
@Beartoe No
Beartoe
Post by Beartoe »
Hi Sasha, I have a question I've asked over on Zepp-OS discussion on Github. (That forum seems, um, pretty sleepy -- I've gotten no response.) I want to change a watchface element based not on a click, but on the value of system data, in this case AQI. I can put a widget up on my WF that has a type of "hmUI.data_type.AQI", but how do I return the actual value of AQI to a variable that I can use to control my display?
Is it just variableName = AQI? Or is this not possible? Also, since this would need to be refreshed, I assume it would go in the bottom part of the WF script.
data_type.AQI should work
It is not possible to get the value and use it in the code
https://docs.zepp.com/docs/watchface/ap ... d/WEATHER/
Here you can see all the sensors from which you can get data at once.
Beartoe
Post by Beartoe »
Thanks, Sasha! So I understand can't make an "AQI sensor" for real-time data. Are there other ways to refresh the variable periodically, say once per hour?
Emiliomc
Post by Emiliomc »
Hi Sasha. I have version 10.3 installed on my Windows 11 (recently updated). It works perfectly. But now I noticed that you have released new updates. I have installed the latest version (12.1) and when I unpack a watchface created with version 10.3 I get a "continue" or "exit" error. The png are loaded, but the preview of the watchface is not shown and the error window that I mentioned is displayed. What have I done or am I doing wrong?
@Beartoe
There are always options. But it is unlikely that you will be satisfied with them.
You can put an application Notify for AQI and watch the data in it.
You can write such an application to share data with the watch face.
You can try to make a watch face that will receive data and site. But I am not sure that this is possible on watch faces.
@Emiliomc Most likely the problem is with the watch face. Send me the watch face and I will check it.
Emiliomc
Post by Emiliomc »
Thanks Sasha. I'll send it to you by private message. I have many spheres created with your application. I have tried this one that I will send you, which is very simple (minimalist). I created this one with version 10.3. It works perfectly on my GTS 4. It opens perfectly on your app version 10.3. But in version 12.1 that error window is shown, in addition to not showing the preview. I haven't uninstalled version 10.3 just in case. Since with version 10.3 I can continue creating spheres.
Has thanked: 128 times
Been thanked: 19 times
Post by taw_bip »
So I'm really trying to make a go of using the tool but I am having difficulty. With the older tool, I could see all the JSON coding and it was straightforward to edit the code.
With the newer tool, it seems you can't see the code until the watchface is packed. But is there a way to adjust the coding before packing?
I opened the following watchface and converted to T-Rex 2 format and did not see an easy way to modify other than selecting the prefabricated elements.
https://amazfitwatchfaces.com/balance/view/239
I don't see where or how to edit the code until the watchface is packed, then I can see the index.js file.
It would help if there was a basic tutorial to follow.
I think if I could follow a tutorial to get the basics down then I might have an easier time.
@taw_bip
You can see the watch face code only after it is packed.
In the editor you can insert ready functions into the watch face code. There is a corresponding widget for this in the System section. But you will not see the results of this code in the editor. The correctness of the code is not checked in any way.
A watch face is a full-fledged JS application and that's why it's impossible to write one tutorial that can explain everything.
Post by taw_bip »
SashaCX75 wrote: 28 Nov 2024, 12:59
Thanks. I think because I have experience with the earlier version of the editor and older watches, I have difficulty adjusting to the new concepts of the latest editor. I see now that you're providing the building blocks. I just need to wrap my head around it because I was used to adjusting the code from the start.
Guydu91
Has thanked: 55 times
Post by Guydu91 »
Hello everyone,
I would like to know if there is a way to create a touch shortcut to Flow (with JavaScript I think...).
Thanks in advance for your answers.
Best regards from France.
Guy.
@Guydu91
Most likely the link will vary depending on the model. For example, for Balance the link to the main page looks like this
hmApp.startApp({ appid: 1038314, url: 'page/gtr/home/index.page'});
I haven't tested this, but it should open the Flow home page.
Guydu91
Post by Guydu91 »
SashaCX75 wrote: 30 Nov 2024, 08:14
@Guydu91
OK Sasha,
Thanks for your quick reply.
I will test this on a future project and let you know the result.
Best regards.
Guy.
Guydu91
Post by Guydu91 »
Guydu91 wrote: 30 Nov 2024, 09:40
@Guydu91
OK Sasha,
Best regards.
Guy.
I installed this shortcut in a watchface for GTS4 (ZeppOS 3.5)... and it worked the first time.
Well done Sasha, you are a genius.
Thanks again for this wise advice.
Kind regards from France.
Guy.
Guydu91
Post by Guydu91 »
Oops!
I got a little excited about the shortcut to Flow...
Actually, it only works once and then it blocks all the other shortcuts.
To reset it, you have to change the watchface and then go back to the initial watchface to make it work again... only once.
So, I think this JS is not quite adapted to the GTS4.
Maybe it's related to ZeppOS 3.5...
Any idea?
Thanks in advance.
After launching any third-party application, the code in the watch faces stops working. Usually it is enough just to switch off the screen and after that the watch face starts working normally.
Guydu91
Post by Guydu91 »
SashaCX75 wrote: 01 Dec 2024, 08:22
OK Sasha, thanks for your answer.
I did try this method but it's not very intuitive and I think most users will think it's a bug.
I prefer to put this feature aside for now until a simple method is available.
Best regards.
Guy.
ZiMiZ
Post by ZiMiZ »
I downloadad some watchfaces, but are .bin, how can i edit that?
Has thanked: 414 times
Been thanked: 2073 times
ZiMiZ wrote: 06 Dec 2024, 10:31
if you mean .BIN for GTS
if you want to edit or modify you must use "AmazFit WatchFace editor for Windows by SashaCX75"
viewtopic.php?p=3789#p3789
Emiliomc
Post by Emiliomc »
Is there a tutorial to create with the SashaCX75 weather widget for several days (forecast) application? I've been searching the forum, but can't find anything. I know how to create watchface with the application and I use almost all the tools, but I want to use this one and I don't know how to use it. I want to make a watchface that has the forecast for the five days following the current one. With maximum and minimum temperatures. Indicating the day of the week and the icon that corresponds to the weather condition that is forecast.
Emiliomc
Post by Emiliomc »
Hi. I have a problem with a watchface. I have created thirteen png for the battery images. They are all the same size and are located correctly at the coordinates I have set. The first three images are a red circle and the next ten are transparent circles. They are named like this (the first three being red): B_00, B_01, B_02, B_03, ..., B_12. In the preview, when you put the battery at 30%, the third image is shown. That is to say; the B_02. Indicating that the battery is already at 30%. Well, on my GTS 4, when I reach 30% (or less than 30%), the red circle does not show. I have restarted the device after installation, but I still have the same problem. I don't know what I'm doing wrong. I don't have numeric values ​​or anything else in "Battery". Just the images.
@Emiliomc
The algorithm of displaying images from the set changes in different firmware versions and on different models. Therefore, if you want the images to change exactly at certain charge values, you need to write your own code instead of using standard widgets.
You can also choose the necessary number of images for your model. But please note that in the standard widget at a small value of charge (about less than 5%) images may not be displayed at all.
Emiliomc
Post by Emiliomc »
Thanks for responding. Honestly, I don't know how to do it with code. But in relation to the second proposal you make to me, I don't know if I understood you correctly. Do you mean that in my case, if instead of creating 13 png (3 png in color), I create 26 png (6 png in color) or even 39 png (9 png in color), I will have a better chance of working correctly with images?
Emiliomc
Post by Emiliomc »
Please, can someone help me?
