Правила форуму
Аватар користувача
Been thanked: 1044 times
Контактна інформація:
Повідомлення SashaCX75 »
v18.1
Version 18.1
Востаннє редагувалось 10 вересня 2026, 17:16 користувачем SashaCX75, всього редагувалось 54 разів.
Omaradsl
З нами з: 02 жовтня 2023, 21:07
Has thanked: 16 times
Been thanked: 8 times
Повідомлення Omaradsl »
Hello Sasha, I enjoy creating watchfaces on the site, my nickname is omaradsl.
https://amazfitwatchfaces.com/search/ba ... rID/772262
i have two questions about your program.
1. The coordinate calculation is damn imprecise because it calculates the size of the png file as a whole. This means that if I have a png file with the image of the number 1, which does not occupy all the pixels of the file, but is positioned in the center, when I go to click on the coordinates to position the image of the dial, the positioning is always wrong.
Зображення
as you can see in the image, clicking on a point on the dial, the program copied the 336x312 coordinates
but the number png is positioned in the coordinates 346x331
and it is like this for all the elements, in fact the positioning in my case takes place manually
2. The corners. I wasn't a genius at math, but is there an easy way to figure out how to calculate the start and end angles of the pointer in a watchfaces?
another image:
Зображення
as you can see the initial angle should be -148 and the final angle 149.
This is a calculation that someone else did, but I can't do it. How do I know on a circle what the corresponding angle is? Wouldn't there be an easier way to calculate it?
Also because when you manage to understand which are the two extremes of the angle, they do not always correspond to the values, for example, of the steps or bpm.
Thank you.
Аватар користувача
@Omaradsl
1. What coordinates are copied when double-clicking on the preview are pasted into the coordinates field. If it is not so, then show a video or a project where it does not work correctly. The fact that the image itself is shifted from these coordinates is because the image itself probably has invisible borders.
2. I don't understand what the problem is. The angle of 0 degrees corresponds to the vertical upward direction. And counting comes from this direction. If you need to precisely set the arrow pointer, just set the minimum or maximum value for this parameter and look at the position of the arrow.
Omaradsl
ok, Thanks Sasha
Аватар користувача
Version 11.0
Mirror
З нами з: 14 травня 2022, 05:41
Has thanked: 205 times
Повідомлення amazfitfacesafrica »
Hello, guys. Please someone with knowledge to help me. If i have a watchface which can unpack with editor 11.0 and have smooth seconds how can I replace the smooth seconds with normal ticking seconds? Thank you.
Аватар користувача
Has thanked: 438 times
Been thanked: 2142 times
Повідомлення asoo »
amazfitfacesafrica писав: 20 червня 2024, 10:56
There are many ways to do this, but I think the easiest way is
You can go to the "Analog time (Pro)" element and remove the check right mark front of "smooth second hand", then pack it in. The second hand will move normally.
Зображення
Thank you, asoo, for help and reply.
andrewr01
З нами з: 01 липня 2019, 09:12
Повідомлення andrewr01 »
When using Numerical values for the month I see only 10 months in the index.js that is created.
Аватар користувача
Повідомлення asoo »
andrewr01 писав: 22 червня 2024, 23:43
If I understand correctly, if you use numbers for show the months
You will find only 0-9 images to use to create month numbers.
Therefore, in the index, there are only 10 image variable values ​​declared.
are 0 , 1 , 2 , 3 , 4 , 5 , 6 , 7 , 8 , 9 which these numbers will be used to display the month in numbers as follows.
01 02 03 04 05 06 07 08 09 10 11 12
if you need Use numbers to display months. but want to create The set of numbers itself requires the element image to handle them, and when you use this element you will have 12 images to display.
lobianco
З нами з: 21 жовтня 2021, 11:08
Повідомлення lobianco »
Good evening everyone
Can anybody help me.
I'm trying to make a watchface that displays the number of steps, I would like to click on that number and change it to the total distance, is there a way to do this in the watchface creator?
If so, what would be the necessary steps?
Thanks in advance
Аватар користувача
Повідомлення asoo »
lobianco писав: 23 червня 2024, 22:24
Thanks in advance
The Edit program has no ready-made options in this section.
If you want, you need to write a user_script to work with element "buttom".
to take the action you want
You can see example scripts from some dials on the web, such as:
https://amazfitwatchfaces.com/gtr/view/37324
You can view the script in the index.js file in the (watchface ) .zip file.
lobianco
Hi, asoo
Thank you very much for your tips, I'm learning a lot, but I've reached a point where I can't put together a user-script to change the color of the hands, would you have any suggestions for me?
If anyone else can help, I would also be very grateful.
З нами з: 12 квітня 2018, 16:29
Has thanked: 134 times
Been thanked: 21 time
Повідомлення taw_bip »
lobianco писав: 26 червня 2024, 14:40
Hi, asoo
@Lattenknaller has several watchfaces that demonstrate how to change hand color, such as these:
https://amazfitwatchfaces.com/gtr/view/36332
https://amazfitwatchfaces.com/gtr/view/38269
lobianco
taw_bip писав: 26 червня 2024, 14:54
Hi, asoo
Hi, Lattenknaller
Thank you very much for the tip, I will study the script, but my biggest problem is javascript.
I've never studied, and to be honest, I don't even know where to start.
lobianco писав: 26 червня 2024, 15:16
Hi, Lattenknaller
When I started learning how to build watchfaces, I would download existing ones and play with them to figure out how they worked. If you'd rather just request someone to build it, make a request in the proper section of the forum.
A lot of the new AI tools can help with Javascript. I was playing around with Claude AI and fed it sample watchface code and it was able to digest that and help with coding.
lobianco
taw_bip писав: 26 червня 2024, 16:35
Hi, Lattenknaller
Hi, taw_bip
I'm from Brazil, and CLAUDE AI does not accept users from some regions, and Brazil is one of those regions, but still, thank you very much for the tip.
lobianco писав: 26 червня 2024, 20:28
Hi, Lattenknaller
Hi, taw_bip
If you have access to a VPN, that can get around some geographic restrictions.
lobianco
taw_bip писав: 27 червня 2024, 13:53
Hi, taw_bip
This is true, but as I use Linux, I don't know which VPN is the best, and for Windows could you recommend one to me.
thanks
lobianco писав: 27 червня 2024, 19:23
Hi, taw_bip
thanks
I use PIA VPN. They have a Linux client. Good luck!
Emiliomc
З нами з: 31 липня 2022, 10:43
Повідомлення Emiliomc »
Hola, ante todo pido disculpas por mi terrible inglés. Cuando creo una watchface con la aplicación (...) los elementos introducidos en la Pantalla Principal (Por ejemplo; hora, fecha, etc), luego indico que añada todos los elementos a la pantalla AOD en la aplicación. Los elementos en ambas pantallas están localizados en las mismas coordenadas "X" y "Y" (Comprobado). Pero una vez instalada la watchface creada en mi reloj, al momento de pasar de Pantalla Principal a AOD, o viceversa, detecto un pequeño salto de los elementos. Creo recordar que ligeramente hacia abajo y hacia la izquierda. He probado a cambiar las coordenadas de AOD 1 pixel hacia arriba y 1 pixel hacia la derecha. Pero sigue ocurriendo lo mismo. Se produce ese pequeño salto. Es como si hubiese una diferencia de coordenadas inferior a 1 pixel. No sé si se puede resolver este problema. O si es algo conveniente cuando se tiene activado el AOD. O si se trata de un defecto de mi reloj Amazfit GTS 4. Espero haberme explicado bien. Gracias.
Аватар користувача
Повідомлення asoo »
Emiliomc писав: 01 липня 2024, 09:17
If I'm not mistaken, it's not a program error. It's caused by firmware. That is set in AOD to move the screen 1-3 pix back and forth at specified intervals. In order to protect the screen from pix's burn-in if it is left open for a long time. This part, if understood correctly, cannot be edited. It is controlled by firmeware.
Emiliomc
Well, you're right. That may be the main reason. I haven't thought about it. It is like the case of AOD in smartwatches. Thank you.
Lattenknaller
З нами з: 09 серпня 2022, 08:43
Has thanked: 62 times
Been thanked: 168 times
Повідомлення Lattenknaller »
Hello everyone,
I have a WF here where I can't solve a problem. WF is created with custom.ttf (i.e. without images). Everything works, but not in the AOD. Background etc.: everything is there, only the digital hours and minutes are missing. In normal mode they are there, with the same size, the same coordinates and the same color. Clock was restarted several times, no improvement.
Does anyone here have a suggested solution without creating images of the individual numbers? This would increase the size of the WF immensely.
edit: No one has any ideas?
I have now tried it with older versions of the editor,... no change.
Востаннє редагувалось 04 липня 2024, 05:38 користувачем Lattenknaller, всього редагувалось 1 раз.
Аватар користувача
@Lattenknaller
I think the problem is in the
Код: Виділити все
if (cc ==0 )
block on line 1607. You are trying to change the visibility of elements that are not on the ADS. In any case, if you remove this block, AOD works. Try to add screen type check to this block.
I also don't understand why you write
Код: Виділити все
 let cc = 0
in the previous line? Because in this case cc ==0 and checking this condition is meaningless. Probably. You should move the declaration of this variable to the very beginning.
Lattenknaller
@SashaCX75
Thank you very much,
I have now added the type check. Until now, I always assumed that it was sufficient to define the variables as "normal" or "idle".
And yes, the declaration belongs at the beginning, it was always there until now, I have no idea why it is now at the bottom. ;-)
Відповісти
Хто зараз онлайн
Зараз переглядають цей форум: Немає зареєстрованих користувачів і 3 гостей
