搜索找到 16 个匹配
- 16 8月 2024, 19:10
- Jump to forum
- Jump to topic
Re: No notification comment
Good morning, I noticed an annoying bug on the site that doesn't allow us to receive a notification when someone comments on our published watchfaces pages.
sometimes I notice that a user has commented even after several days
I have to continually manually check each page of my watchfaces to ...
- 16 8月 2024, 19:22
- Jump to forum
- Jump to topic
- 16 11月 2024, 09:58
- Jump to forum
- Jump to topic
Re: How to set the Price of the WF ?
Unfortunately our community, unlike other platforms such as facer.io, does not consider donation a tool to reward our work.
Unfortunately, as a platform, we cannot provide a payment processing system like Facer.io due to the numerous legal and logistical challenges it involves. From the very ...
- 16 11月 2024, 17:45
- Jump to forum
- Jump to topic
Dear Gik ,
mine was not a criticism of our platform, which I consider fantastic, because it embodies the open source spirit that I have always pursued in my life. Making a work that requires sacrifice and commitment free is an act of good that the world needs in all fields, from pharmaceuticals ...
- 14 12月 2023, 17:55
- Jump to forum
- Jump to topic
Re: AmazFaces for iOS [Support]
App version: 4..4.334 Stable
Watch model: Balance
Phone model: iPhone 14 pro max
OS version: iOS 17.2
Hi to all. I have a problem with install faces on my Balance and Iphone 14 pro max.
This is the message.
https://i.postimg.cc/fLv3gv8c/73354.jpg
Anyone can help me please?
Thank you ...
- 03 6月 2024, 16:47
- Jump to forum
- Jump to topic
Omaradsl
1. What coordinates are copied when double-clicking on the preview are pasted into the coordinates field. If it is not so, then show a video or a project where it does not work correctly. The fact that the image itself is shifted from these coordinates is because the image itself probably ...
- 25 9月 2024, 20:51
- Jump to forum
- Jump to topic
@Omaradsl Interface icons are standard size and I don't plan to change them.
The source code of the editor is available and you can modify the interface to suit your own needs.
https://github.com/SashaCX75/AmazFit-Wa ... /tree/test
- 31 10月 2024, 21:17
- Jump to forum
- Jump to topic
@Omaradsl
Both links are working
- 15 4月 2023, 13:12
- Jump to forum
- Jump to topic
Re: New GTR Mini
https://www.dropbox.com/s/ugmfqg0xdv8qbcd/ImageToZeppOS.zip?dl=0
Updated utility for converting images. The number in the input field determines the number of colors in the image at which the improved algorithm is triggered (or you can force the enhanced algorithm to be enabled).
Improved algorithm ...
- 20 2月 2024, 15:40
- Jump to forum
- Jump to topic
Re: How to edit a watchface(FOR BALANCE) downloaded from Zepp app store?
Most watch faces in the "zepp store". It use script are encrypted and cannot be unpacked with Sasha's Editor. However, Sasha's Editor can unpack images. You can use the images after unpack, and bring it to create a new one.
You can download that watchface file you mentioned here.
https://mmk.pw/en ...
- 19 9月 2024, 01:58
- Jump to forum
- Jump to topic
Re: Watchfaces Editor does not recognize some watchface
is the watch face editor fitted the new watch t rex 3?
You can use the official zepp editor to create a watch face for T-rex 3 ( https://watchface.zepp.com ). You must register as required by zepp.
Information about using Zepp's Editor to create a watch face for
T-Rex3
https://amazfitwatchfaces ...
- 24 9月 2024, 17:42
- Jump to forum
- Jump to topic
Re: Resources bank
Vector black and white icons
https://fonts.google.com/icons?icon.platform=web
https://pictogrammers.com/library/mdi/
- 05 10月 2024, 11:12
- Jump to forum
- Jump to topic
Re: issue smooth seconds
sorry asoo, you're right, I wasn't very precise in describing the problem, and I thank you for your answer.
the problem noted is that the hand goes back one second in the cycle in which the dial is turned on. I attach the video to you.
https://drive.google.com/file/d/1Y347-g5-RMk5WJ ...
- 18 7月 2024, 05:51
- Jump to forum
- Jump to topic
Re: Gradient problem with png images
Send me the original image files (before converting them to dials). I will see if there is anything I can do about it.
- 19 7月 2024, 02:49
- Jump to forum
- Jump to topic
https://i.postimg.cc/TPMFjwMN/IMG-3866.png
LOOK:
installing your image on balance, it appears grainy
The balance dont manage correct gradient that you have create
This is what I understand. If there are any mistakes, I apologize.
I think the problem might be with the pack.
In the pack process ...
- 01 11月 2024, 21:01
- Jump to forum
- Jump to topic
Re: Requesting creation of "Pro Analog" [Amazfit Balance]
Thank you very much Omaradsl
