Has thanked: 14 times
Version 8.1
Mirror
rma013
Post by rma013 »
first of all: thanks for the great editor!
I created a watchface and created an aod-face too (copied all elements).
Installing it on a GTR4 shows the watchface, but aod-face keeps being the default from internal watchface.
How can I find out, why my aod-face will not be used?
brunoandreotti
Post by brunoandreotti »
Is there a way to add an custom AOD to use even with different custom watchfaces?
ZduneX25
Been thanked: 6 times
Post by ZduneX25 »
@SashaCX75 have you heard about any other way to install MiniPrograms than through DeveloperMode and QR code?
@ZduneX25 It can be installed in the same way as a regular watch face. But this is not the best way. With this method, the program can only be uninstalled using a third-party file manager utility. And if the program has an app-side part, then it will not work.
trogoz
Post by trogoz »
this editor works great, I can generate zip files and upload them to my amazfit band 7 no problem, thanks!
Only one question, this warning appears sometimes when I try to generate the zip with some images, it is not translated from russian so I cannot understand it, any help?
Has thanked: 425 times
Been thanked: 2131 times
trogoz wrote: 06 Aug 2023, 12:13
The image you are using does not meet the standards of the program.
The image should be a (PNG) regular uncompressed และมี format แบบ 24 หรือ 32bit color.
You can preview images from images you can pack
rush2112 wrote: 19 Aug 2023, 14:49
Can someone tell me when I make a WF , how can I lock my work ( watch face ) .....maybe a scripts where can I find the scripts for locking my work . Help
Thank You
I think your question is not related to the latter ( Amazfit GT3 Series Watch Face Editor (GTR 3, GTR 3 Pro, GTS 3) ).
If you want to ask questions that are not related to the main topic, it is recommended to open a new topic.
Or try opening a new thread to ask about tools here.
viewforum.php?f=170
Version 8.2
Mirror
rma013
Post by rma013 »
could you please write some hints about how to replace an idle mode watchface on a GTR4?
rma013 wrote: 26 Aug 2023, 04:27
I'm not sure of your question.
If you mean to use Program to generate AOD ( idle mode )
In the program there is an AOD section where you can, You can copy the home screen to an AOD or you can create an AOD with a different layout from the home screen.
As for the AOD, you can enable it in the attached image.
rma013
Post by rma013 »
Thank you very much for your attention.
May be I did something wrong. I created a watchface and then copied items to aod. But when I upload the watchface, the active watchface changed to my one, but the idle watchface stayed at factory provided one.
I already searched developer doku but I did not find hints about dos and don'ts
So you say - all I have to do is select aod and create a watchface? Do I have to create separate archives for the watchface and the aod watchface?
rma013 wrote: 27 Aug 2023, 04:43
No need to split, you can add AOD directly to the main watch face.
When you use that watchface when the watch into AOD, it will immediately use the AOD watchface that is in that watchface.
However You can't add AOD alone to use it separately from the home screen (which screen you choose, the watch will only use that face's AOD).
rma013
Post by rma013 »
May I ask you to have a look at my watchface?
From your description I could not identify my failure.
I only can say, that the watch does not use my aod-watchface, but it uses my regular watchface
RMA03n-230722.zip
(407 KiB) Downloaded 653 times
rma013 wrote: 28 Aug 2023, 03:19
I don't see any errors in the watchface you sent me.
You have created the home screen and AOD correctly.
So I don't know what problems you encountered using AOD.
- ? GTR4 doesn't show your generated AODs.
- ? AOD doesn't work properly ( in this case please tell me what issue you found )
- ? Have you enabled AOD on your watch yet?
I don't have GTR4, so I can't test it on real devices.
In GTR3 you can set your watch to use the system's AOD, which if enabled.The AODs you create will not be used, the watch will use the AOD built into the watch.
But I'm not sure this case on GTR4.
but anyway If you want to use the AOD you created.
You have to go into the settings on the watch to use the screen style AOD of the watch face.
Otherwise, the clock maybe use the AOD from system and be sure to enable AOD.
Otherwise, when the display time has elapsed. The screen will just be black.
You can learn about enabling AOD from this guide.
Search for "always on Display".
https://amazfit-support.cdn.bcebos.com/ ... 697930.pdf
Lattenknaller
Has thanked: 60 times
Been thanked: 140 times
Post by Lattenknaller »
Hello experts, have a problem here that I can not get solved.
Is it somehow possible to hide rotating Text, by pressing a button? the usual method with
.setProperty(hmUI.prop.VISIBLE, false);
does not work. Is there any script guru here who can nudge me in the right direction? In my case I have a WF where the distance and battery are displayed at 90 degrees, but which I want to hide by button.
@Lattenknaller If other methods do not work, then you can change the coordinates and move the element off the screen.
Lattenknaller wrote: 28 Aug 2023, 11:49
I ran into this problem too. So I use the method Replace with an empty image on "normal_xxxxxxxx_TextRotate_ASCIIARRAY[]".
and refresh the screen by turning off the screen " const result = hmSetting.setScreenOff() " When pressing the screen again, it will display correctly.
Example I have done
https://amazfitwatchfaces.com/amazfit-band/view/139
I think it's not the best way but it can work.
Hope it's more or less helpful.
rma013
Post by rma013 »
Thank you very much!
That was the key.
Localized menue is a bit misleading - or at least I did not understand the meaning.
Now it works as expected! - Thank you!
yangqlong
Post by yangqlong »
有没有中文版本的编译软件,很多大佬设计的表盘6.5版本都打不开,晕死。如果有好心人发一个给我
yangqlong wrote: 23 Sep 2023, 06:59
communication in this forum, if possible, please use English. As stated in the forum rules
The program available for download can already be changed to Chinese.
Setting ---> Language ----- ( select your language )
@yangqlong
I don't translate the programme. I only use the translation that was provided to me. The Chinese translation will be updated in the next version. But still not all new functions will be translated.
yangqlong
Post by yangqlong »
Dude, do you know that we can't download it? We need a ladder (VPN) to download it. If it's convenient, please make a version with Chinese language settings. By the way, is the altitude set in the compiler?
Version 9.0
Mirror
arturovivo
Post by arturovivo »
Thank you for this great tool. I am quite inexperienced so I wanted to ask if it is possible to open bin files as well as zip files.
Users browsing this forum: Amazon [Bot] and 2 guests
