How do you copy it to Falcon?
- 管理员
New GTR Mini
版面规则
Just use file explorer to copy files from download/AmazFaces/[watch model]/xxx
Now I'm joining the beta program, update the app to beta version.
then the app can upload the watchface on GTR mini as it should. no need to manual copy the watchface files.
Thanks for your hard work.SashaCX75 写了: 12 4月 2023, 15:35Test utility for converting images to watchface format for GTR mini. Judging by the previous message in normal mode, the image is converted normally.
Who can check with the switch for forced use of the improved algorithm turned on.
https://www.dropbox.com/s/pk9s8yos91akf ... t.zip?dl=0
I have test the tool and it work great, the converted image could show on GTR mini without problem
If select use the improved algorithm the converted image size is 2-5times bigger than normal.
if not select the improved algorithm the image size is close to old format and it could show on the watch without problem.
Left: old image format from falcon watchface
Mid: new image format for GTR mini converted by zepp official watchface editor
Right: new image format for GTR mini converted by using image converter tool (force use the improved algorithm)
- SashaCX75
- 来自: Ukraine
- Has thanked: 13 time
- Been thanked: 1036 time
- 联系:
Updated utility for converting images. The number in the input field determines the number of colors in the image at which the improved algorithm is triggered (or you can force the enhanced algorithm to be enabled).
Improved algorithm can increase file size and conversion time. But in this mode there should be no loss of colors in the image. Therefore, this mode is best used if the image has translucency or smooth gradients.
Thankyou.SashaCX75 写了: 15 4月 2023, 13:12https://www.dropbox.com/s/ugmfqg0xdv8qb ... S.zip?dl=0
I use your "watchface editor for GT3" and there are some watchface that when unpack the dial there is only background detected no other element detected.
this is sample of the watchface that have problem
https://amazfitwatchfaces.com/gtr/view/28884
https://amazfitwatchfaces.com/gtr/view/31044
- 来自: ͼͽ Thailand ͼͽ
- Has thanked: 419 time
- Been thanked: 2110 time
The watch face you mention have add custom script which does not meet the standard of the sasha's program, so sasha's program cannot be unpacked that watchface. The program can only convert the image resource, but the script cannot do it.kkeonline 写了: 16 4月 2023, 17:40
I use your "watchface editor for GT3" and there are some watchface that when unpack the dial there is only background detected no other element detected. this is sample of the watchface that have problem
Does anyone have any of the built-in watchfaces that come in the GTR Mini? I'd like to convert it for my GTR 4 if no one has done it yet.
Hello. Would it be possible to modify this face to work with the GTR Mini?
/storage/emulated/0/Download/AmazFaces/gtr_GTR_2/1618042803_ef9dd45846/1618042803_ef9dd45846.gif
在线用户
正浏览此版面之用户: 没有注册用户 和 1 访客
