You can download the beta version, but in a few days it will be in the stable version.
Amazface android latest version (4.0)
watch GTR mini
Now the app add gtr mini to select
https://i.ibb.co/ftyWdqr/Screenshot-20230414-213703.jpg
however no connect/upload button to upload the watchface ...
Pesquisa resultou em 12 ocorrências
- 19 Mar 2023, 13:23
- Jump to forum
- Jump to topic
Re: New GTR Mini
From the official web
https://www.amazfit.com/products/amazfit-gtr-mini
Amazift GTR Mini running Zepp OS ( Version 2.0)
Resolution 416x416
Same resolution as Amazfit Falcon.
OS is Zepp OS ( Version 1.0 )
So , from the example that the GTR4 can open the GTR3 dial.
I think watchface from falcon ...
Resolution 416x416
- 05 Abr 2023, 05:49
- Jump to forum
- Jump to topic
Re: New GTR Mini
The images for the GTR Mini look weird. Like they were made wrong. I would like to see a real working dial to make sure that this is not a mistake in the online editor.
- 09 Abr 2023, 18:08
- Jump to forum
- Jump to topic
Re: New GTR Mini
Other image viewers can open these files too. But everywhere they look distorted. You can even see it in your screenshots. I guess it has to do with the sequence in the color map. This is clearly visible if you encode an image with a small number of colors and then change the extension to tga and ...
- 12 Abr 2023, 04:54
- Jump to forum
- Jump to topic
Re: New GTR Mini
GTRmini users please help to test this watch face.
This watch face is made for Test converting the image to the format of GTRmini.
Anyone who has tested it, please inform the result.
thank you very much
https://i.postimg.cc/90FgCTXH/1678459821-72fa88a305.gif
https://amazfitwatchfaces.com/gtr ...
thank you very much
- 12 Abr 2023, 09:47
- Jump to forum
- Jump to topic
Re: New GTR Mini
thank you very much
G317_GTRmini.zip
This ...
- 12 Abr 2023, 15:35
- Jump to forum
- Jump to topic
Re: New GTR Mini
Test utility for converting images to watchface format for GTR mini. Judging by the previous message in normal mode, the image is converted normally.
Who can check with the switch for forced use of the improved algorithm turned on.
https://www.dropbox.com/s/pk9s8yos91akf ... t.zip?dl=0
- 13 Abr 2023, 17:46
- Jump to forum
- Jump to topic
Re: New GTR Mini
ZduneX25 I don't plan to add terminal mode work. A little later I will clean up the code and post it. Then whoever wants can remake it to their needs.
- 14 Abr 2023, 15:15
- Jump to forum
- Jump to topic
Re: New GTR Mini
Now amazfaces app add the gtr mini to select
https://i.ibb.co/BL4Ld5y/Screenshot-20230414-173424.jpg
I have to copy the file to falcon folder and swap the watch selection to ...
- 15 Abr 2023, 13:12
- Jump to forum
- Jump to topic
Re: New GTR Mini
https://www.dropbox.com/s/ugmfqg0xdv8qbcd/ImageToZeppOS.zip?dl=0
Updated utility for converting images. The number in the input field determines the number of colors in the image at which the improved algorithm is triggered (or you can force the enhanced algorithm to be enabled).
Improved algorithm ...
- 17 Abr 2023, 01:43
- Jump to forum
- Jump to topic
Re: New GTR Mini
I use your "watchface editor for GT3" and there are some watchface that when unpack the dial there is only background detected no other element detected.
https://i.ibb.co/xj9SzYf/2023-04-17-002757.png
this is sample of the watchface that have problem
https://amazfitwatchfaces.com/gtr/view ...
