New GTR Mini
MGBWHIP
Post by MGBWHIP »
kkeonline wrote: 14 Apr 2023, 14:43
Now amazfaces app add the gtr mini to select
however no connect/upload button to upload the watchface
I have to copy the file to falcon folder and swap the watch selection to falcon to upload.
How do you copy it to Falcon?
kkeonline
Has thanked: 12 times
Post by kkeonline »
MGBWHIP wrote: 14 Apr 2023, 19:40
Just use file explorer to copy files from download/AmazFaces/[watch model]/xxx
MGBWHIP
Post by MGBWHIP »
Thank you.
kkeonline
Post by kkeonline »
MGBWHIP wrote: 15 Apr 2023, 10:00
Thank you.
Now I'm joining the beta program, update the app to beta version.
then the app can upload the watchface on GTR mini as it should. no need to manual copy the watchface files.
kkeonline
Post by kkeonline »
SashaCX75 wrote: 12 Apr 2023, 15:35
Test utility for converting images to watchface format for GTR mini. Judging by the previous message in normal mode, the image is converted normally.
Who can check with the switch for forced use of the improved algorithm turned on.
https://www.dropbox.com/s/pk9s8yos91akf ... t.zip?dl=0
Thanks for your hard work.
I have test the tool and it work great, the converted image could show on GTR mini without problem
If select use the improved algorithm the converted image size is 2-5times bigger than normal.
if not select the improved algorithm the image size is close to old format and it could show on the watch without problem.
Left: old image format from falcon watchface
Mid: new image format for GTR mini converted by zepp official watchface editor
Right: new image format for GTR mini converted by using image converter tool (force use the improved algorithm)
Been thanked: 1006 times
Updated utility for converting images. The number in the input field determines the number of colors in the image at which the improved algorithm is triggered (or you can force the enhanced algorithm to be enabled).
Improved algorithm can increase file size and conversion time. But in this mode there should be no loss of colors in the image. Therefore, this mode is best used if the image has translucency or smooth gradients.
kkeonline
Post by kkeonline »
SashaCX75 wrote: 15 Apr 2023, 13:12
Thankyou.
I use your "watchface editor for GT3" and there are some watchface that when unpack the dial there is only background detected no other element detected.
this is sample of the watchface that have problem
https://amazfitwatchfaces.com/gtr/view/28884
https://amazfitwatchfaces.com/gtr/view/31044
Has thanked: 404 times
Been thanked: 2018 times
kkeonline wrote: 16 Apr 2023, 17:40
The watch face you mention have add custom script which does not meet the standard of the sasha's program, so sasha's program cannot be unpacked that watchface. The program can only convert the image resource, but the script cannot do it.
ismaelf
Post by ismaelf »
Does anyone have any of the built-in watchfaces that come in the GTR Mini? I'd like to convert it for my GTR 4 if no one has done it yet.
MGBWHIP
Post by MGBWHIP »
Hello. Would it be possible to modify this face to work with the GTR Mini?
/storage/emulated/0/Download/AmazFaces/gtr_GTR_2/1618042803_ef9dd45846/1618042803_ef9dd45846.gif
