Has thanked: 14 times
Unkash
Post by Unkash »
hi, if i'd like to port my watch face (in my gtr3) to gtr2, how can i do this?
aleste2
Post by aleste2 »
I've been using your editor for some time, and now I am trying to use an editable background. I see how to introduce the desired number of images (Add background), how to select the image (background image), but I do not understand what is the foreground image. Also I do not see where is the definition of the zone to press to change background or how to change it in the watch. Am I missing something or I need to edit manually the code?
I respond myself: background selection is made in watchface selection page (long press).
Still I do not see what is the foreground image.
Unkash Use editor for GTR 2
aleste2 I think that from the name it is clear that this is an image that is shown above the rest of the elements. Usually this is a ring around the perimeter of the dial and filling outside the ring. Such an image is clearly visible when there are other editable elements and you scroll through the screens with their settings.
Unkash
Post by Unkash »
SashaCX75 wrote: 24 Jan 2023, 17:30
@Unkash Use editor for GTR 2
ok, thx, but my files are in .zip (for gtr3) and gtr2 use .bin files
sorry, im newbie
aleste2
Post by aleste2 »
@aleste2 I think that from the name it is clear that this is an image that is shown above the rest of the elements. Usually this is a ring around the perimeter of the dial and filling outside the ring. Such an image is clearly visible when there are other editable elements and you scroll through the screens with their settings.
Yes, the name was clear, but I was not able to see when it appears. Thank you.
Xemic
Post by Xemic »
First of all a massive thank you for the tool your created. I has helped me create a few watch faces.
i have some questions
1. it possible to slant or tilt text / images with the the tool?
2. is it also possible to add alignment to the Day of the week (Center or Right)? Either in tool or the index.js file, at present it's on Left.
Thank you.
Xemic 1. Text cannot be rotated using the editor. This can be done with code.
2. I didn't understand the question. The day of the week is made as a set of pictures of the same size. As you draw text in them (in the center of the picture or from some edge), so it will be displayed on the clock.
Xemic
Post by Xemic »
Sasha
1. Thanks for the answer - do you have a sample of code were rotation was applied?
2. Sorry what i meant was is there a way to add alignment option to Day of Week and Month
Xemic
Post by Xemic »
Sasha please ignore my questions, just noticed your GitHub links that answers my questions.
TheChemist
Post by TheChemist »
For watchfaces with digital time, the tool uses images of digits from 0 to 9 and makes all numbers with them. Is it possible in some way to use seperate images for all numbers from 0 to 23 (or from 1 to 24)?
That would open up a whole new way of showing time with images.
Superwitschi
Has thanked: 8 times
Post by Superwitschi »
My smooth second freezes every 15 seconds. Somone know why? https://amazfitwatchfaces.com/gtr/view/31117
tag heuer update
Can somone please have a look at it?
Never mind, i found the solution.
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Post by demiurg1 »
Interesting question about numbers 00 to 12 or 00 to 24 that could be presented as pictures. The problem, however, will not be with hours, but with minutes, because there are as many as 60 of them. Seconds are similar. So many graphics will probably overload the watch system too much.
I once designed my own graphic numbers. I was inspired by the movie Predator. Link to this watch face: https://amazfitwatchfaces.com/gtr/view/16902 .
ZduneX25
Been thanked: 6 times
Post by ZduneX25 »
Where is the question? Pattern is 0123456789, ten images. There is no variable that needs more and OS will not let you use more even if you want to.
SashaCX75 is there a way to load boolean after onDestroy is called?
i control battery progress widget by boolean:
hmFS.SysProSetBool('dial2', false);
then once button is pressed:
hmFS.SysProSetBool('dial2', true);
and finally:
const arc2 = hmFS.SysProGetBool('dial2')
if (arc2 === true) {
    dial2_normal_battery_circle_scale.setProperty(hmUI.prop.VISIBLE, true);
 } else {
    dial2_normal_battery_circle_scale.setProperty(hmUI.prop.VISIBLE, false);
it works well if users does not use AOD, if AOD is enabled watch face resets boolean status and progress is empty after raise to wake gesture..
ZduneX25
I have a SysProSetBool that works great for passing data to an AOD screen. So either this function works differently on different models or you are doing something wrong.
Zecodorna
Post by Zecodorna »
How do I add a shortcut to the calendar in t-rex 2?...I changed the name of a shortcut in index.js, but I don't know if I put the right name. I click on the shortcut and nothing happens.
normal_calendar_jumpable_img_click = hmUI.createWidget(hmUI.widget.IMG_CLICK, {
x: 178,
y: 289,
w: 100,
h: 100,
src: '98.png',
type: hmUI.data_type.CALENDAR,
Replaces the word "SUN_CURRENT" with "CALENDAR"
Lattenknaller
Has thanked: 60 times
Been thanked: 133 times
Post by Lattenknaller »
Zecodorna
replace
normal_sunrise_jumpable_img_click = hmUI.createWidget(hmUI.widget.IMG_CLICK, {
x: 178,
y: 289,
w: 100,
h: 100,
src: '98.png',
type: hmUI.data_type.SUN_CURRENT,
with
normal_img_click_1 = hmUI.createWidget(hmUI.widget.IMG, {
x: 178,
y: 289,
w: 100,
h: 100,
src: '98.png',
normal_img_click_1.addEventListener(hmUI.event.CLICK_DOWN, function (info) {
hmApp.startApp({ appid: 1, url: 'ScheduleCalScreen', native: true })
Lattenknaller
SashaCX75 or @everyone :D
I have a problem here with my new project that I can't identify.
Digital hour display without preceding ZERO and right-aligned. Normally everything is fine, also in your tool are at AOD all good from. But on the clock then not. There the hour display is moved to the right (see pictures)
normal
AOD
Also the code looks actually good.
normal
normal_digital_clock_img_time = hmUI.createWidget(hmUI.widget.IMG_TIME, {
              hour_startX: 138,
              hour_startY: 107,
              hour_array: ["big_00.png","big_01.png","big_02.png","big_03.png","big_04.png","big_05.png","big_06.png","big_07.png","big_08.png","big_09.png"],
              hour_zero: 0,
              hour_space: 3,
              hour_align: hmUI.align.RIGHT,
              minute_startX: 256,
              minute_startY: 107,
              minute_array: ["big_00.png","big_01.png","big_02.png","big_03.png","big_04.png","big_05.png","big_06.png","big_07.png","big_08.png","big_09.png"],
              minute_zero: 1,
              minute_space: 3,
              minute_follow: 0,
              minute_align: hmUI.align.RIGHT,
AOD
idle_digital_clock_img_time = hmUI.createWidget(hmUI.widget.IMG_TIME, {
              hour_startX: 138,
              hour_startY: 107,
              hour_zero: 0,
              hour_space: 3,
              minute_startX: 256,
              minute_startY: 107,
              minute_zero: 1,
              minute_space: 3,
              minute_follow: 0,
              show_level: hmUI.show_level.ONLY_AOD,
Is there any solution, except to put the 0 in front again?
With 0 in front the display does not move.
ZduneX25
Post by ZduneX25 »
SashaCX75 boolean issue fixed by setting
if (screenType = hmSetting.screen_type.AOD) {
i thought is saves state for all screen types by default, turns out it does not on gtr4
Lattenknaller
Here is a test dial with a minimum number of elements. On it, alignment works as expected on the main screen and on AOD. If this is not the case for you, then these are the features of your watch model.
UPD. I made a mistake and answered the wrong one.
test2.zip
(88.82 KiB) Downloaded 214 times
Zecodorna
Post by Zecodorna »
Please...How do I make "aod" not move from the center?
ZduneX25
Post by ZduneX25 »
You can't, it's pixel protection. AOD widgets can and will slightly move from time to time.
Xemic
Post by Xemic »
Please can you help, i noticed that if i add icon to "Digital Time Hours" it overlays over Minute and Seconds, regardless of how it's arranged. If i put Hour at bottom and Minute at the top the icon still overlays.
e.g. This is the design and layout on watch face editor.
But I get this on the watch.
Is this something that can change in the index.js file?
1mylord
Post by 1mylord »
Thank you always.^^
burn79
Post by burn79 »
Hi, does anyone have the code for automatic lock?
Xemic Indeed there is such a problem. On the screenshots, I do not see the difference, so I can not understand what you want to do.
It should help if you change the order of the displayed time elements. For example make minutes below hours. Or if seconds are not needed, then you can display them outside the screen but make them below the minutes.
