Weather render problem in AmazfitBipTools-1.0.3.1
netoper
Been thanked: 8 times
Post by netoper »
hello.
i have this code for weather text temperature:
       "Temperature": {
            "Current": {
                "Number": {
                    "TopLeftX": 138,
                    "TopLeftY": 136,
                    "BottomRightX": 171,
                    "BottomRightY": 145,
                    "Alignment": "TopRight",
                    "Spacing": 2,
                    "ImageIndex": 50,
                    "ImagesCount": 10
                "MinusImageIndex": 102,
                "DegreesImageIndex": 103
in editor looks fine and the text is aligned to the right side. but when create bin file with AmazfitBipTools-1.0.3.1, text is aligned from left. amazfitbiptools ignore my settings ("Alignment": "TopRight",), or i missed something? thank.
Been thanked: 2088 times
I would like to help you to solve this issue.
But, Could you please send your "file.BIN" to me ?
netoper
Post by netoper »
thank you for reply. i re-created watchface again, and now is ok ;) i don't know where the problem was.
TXK
Has thanked: 149 times
Been thanked: 97 times
Post by TXK »
The way to solve the problem is:
1. https://v1ack.github.io/watchfaceEditor/
2.[DESIGN]-[FIX COORDINATES]
3.Re layout,Export JSON
netoper
Post by netoper »
OK, the problem is still here. This watch face https://amazfitwatchfaces.com/bip/view/23630 on preview show battery number, night temp wrong. I use "TopRight" align. For current temp (below of weather icon) i use "TopCenter". In editor is all ok and is positioned correctly, but when i create .bin file, generated preview is with wrong aligment.
Kensupen
Been thanked: 6 times
Post by Kensupen »
You have to go to the "Edit" tab and make sure the settings
"TopLeftX": 0,
"TopLeftY": 0,
"BottomRightX": xx,
"BottomRightY": xx,
Are at least as large as your fonts added together plus spacing. If the box is too small on the "Design" tab, it'll look right in the editor, but not when made into a bin file.
netoper wrote: 29 Apr 2019, 17:58
Please see this repack BIN
duotone cyan_packed.bin
(45.77 KiB) Downloaded 300 times
netoper
Post by netoper »
thank you guys ;) i understand how now.
Users browsing this forum: Baidu [Spider] and 1 guest
