samonefit
Post by samonefit »
Dear All,
i've an issue when i try to open a project. During importing appears this disclaimer:
"Unable to open image:0001.png. You do not have permission to read the file, or the image is damaged."
This is repeating for all the images of the watchface.
Thanks so much.
1mylord
Post by 1mylord »
Please tell me how to apply a soft second hand to GTR4.
It is different from GTR3PRO.
quadraf
Post by quadraf »
Sasha, Thank you very much for your great workl!
The rotation animation in my gtr 4 watch does not work.
I would love to see it working as in this watchface:
https://amazfitwatchfaces.com/gtr/view/27770
I converted with your app. to gtr 4 but the animation will not work...
Greetings Hans.
It seems that animation works differently on GTR4 than on GTR3. You can read about motion animation on ZeepOS 2 here https://docs.zepp.com/docs/reference/de ... animations
I'm not sure that rotation animation can be done on GTR4. Therefore, most dials with a smooth second hand will not work. Here's a working example of a dial with a smooth second hand for the GTR 4
https://amazfitwatchfaces.com/gtr/view/28593
quadraf
Post by quadraf »
Thanks for the fast reply!
The only hope the rotation animation will come available in the near future.
One would expect that the features would expand from older models...
Hasnain732
Has thanked: 7 times
Post by Hasnain732 »
Hi everyone. please anyone give me a short demo/tutorial on how to build my own watch face with this application? i am a designer and have 2 years experience in the graphics (adobe Illustrator)/ thanks
bird81309
Post by bird81309 »
I really like some of the GTR 4 dials built in zepp. Is there any way to extract these official dials?
Has thanked: 130 times
Been thanked: 20 times
Post by taw_bip »
samonefit wrote: 19 Oct 2022, 07:54
Dear All,
Thanks so much.
I'm also getting errors when I tried to unpack a dial, which hasn't happened before.
Post by taw_bip »
Hasnain732 wrote: 30 Oct 2022, 05:16
A couple places with some good information:
https://web-archive-org.translate.goog/ ... r_pto=wapp
https://reddit.com/r/amazfit/comments/o ... e/h7wqozg/
https://voonze.com/how-to-create-your-o ... fit-watch/
https://tiktektok.com/tips-tricks/how-c ... faces.html
https://www.youtube.com/watch?v=vf443DhUmyU
https://www.youtube.com/watch?v=dAMAFwZBCS8
There is a tool called "amazfitfontgenerator" that is very handy to quickly create all the numbers and text for a particular size in PNG format so it has the transparency. It's a great time saver. I don't think the link here works anymore so I can upload it when I get a chance.
Hasnain732
Thanks alot
Jel
Post by Jel »
quadraf wrote: 27 Oct 2022, 14:48
Hello quadraf, based on the hint of SashaCX75 and the work of StarScreaM ( https://amazfitwatchfaces.com/gtr/view/28593 ), I was able to let my second hand on GTR4 running smooth.
Here is what I did ( please be aware, I had to enter a spaces into the code line of hm.Sensor.createSensor before ".id.Time" to be able to post the code ) :
// normal_analog_clock_time_pointer_second = hmUI.createWidget(hmUI.widget.TIME_POINTER, {
            //   second_path: '0005.png',
            //   second_centerX: 233,
            //   second_centerY: 233,
            //   second_posX: 8,
            //   second_posY: 223,
            //   show_level: hmUI.show_level.ONLY_NORMAL,
// Insert after section "normal_analog_clock_time_pointer_second = hmUI.createWidget(hmUI.widget.TIME_POINTER"
// Take over values to "sec_pointer = hmUI.createWidget(hmUI.widget.IMG", below
// Remove your original section "normal_analog_clock_time_pointer_second = hmUI.createWidget(hmUI.widget.TIME_POINTER"
// Modify section "onDestory()"
           // Smooth Seconds
    		let sec_pointer;
    		let clock_timer;
            // pos_x and pos_y and center values taken from above. The 8 and 223 frome above.
            // set PNG name here
            sec_pointer = hmUI.createWidget(hmUI.widget.IMG, {
              x: 0,
              y: 0,
              w: 466,
              h: 466,
              pos_x: 466 / 2 - 8,
              pos_y: 466 / 2 - 223,
              center_x: 233,
              center_y: 233,
              src: "0005.png",
              angle: 0,
            const now = hmSensor.createSensor(hmSensor .id.TIME);
            const vDelegate = hmUI.createWidget(hmUI.widget.WIDGET_DELEGATE, {
                resume_call: (function () {
                    console.log('ui resume');
                    const animFps = 60;                 // Frames per second
                    const animRepeat = 1000/animFps;    // execute every <animRepeat>ms
                    const animProgress = 6/animFps;
					let animAngle = 0;
                    let animDelay = 0;
					var sec = now.second;
                    if (animAngle == 0) {
                        var startSec = sec*6;
                        sec_pointer.setProperty(hmUI.prop.ANGLE, startSec);
                    clock_timer = timer.createTimer(animDelay, animRepeat, (function(option) {
                            animAngle = animAngle + animProgress
                            sec_pointer.setProperty(hmUI.prop.ANGLE, startSec + animAngle);
                pause_call: (function () {
                    console.log('ui pause');
					timer.stopTimer(clock_timer);
            // End Smooth Seconds
            // Add following to section "onDestory()"
          onDestory() {
            console.log('index page.js on destory invoke')
Best regards.
Post by taw_bip »
Hasnain732 wrote: 01 Nov 2022, 17:09
Thanks alot
Here's the link to those tools with the Amazfit font generator:
https://mega.nz/file/Gp8hgKzS#aOSrVecUS ... qJhqkUb-5U
quadraf
Post by quadraf »
Jel wrote: 01 Nov 2022, 22:32
Hello quadraf, based on the hint of @SashaCX75 and the work of @StarScreaM ( https://amazfitwatchfaces.com/gtr/view/28593 ), I was able to let my second hand on GTR4 running smooth.
Hello Jel,
Thank you for this information!
We are gooing to test this... :D
And maybe Sasha will incorperate this into the editor... :o 8-)
Small comments to the code.
Values 466 are for GTR 4, for other models it is different depending on the screen resolution.
To find out the required values for the pos_x parameter, you need to look at the second_posX value in the commented out part of the code.
I think the FPS value of 60 is a lot, probably half as much is enough.
roigreenberg
Post by roigreenberg »
Moving this discussion to here since it seems unrelated to the app.
I created a watchface, and I can't install it for some reason.
I tried to install from 2 different apps, both from local file and uploaded one.
There is no error, but the watchface simply doesn't installed.
I added the zip file, maybe you can find something I missed
Watch_face.zip
(114.82 KiB) Downloaded 182 times
Been thanked: 2122 times
roigreenberg wrote: 02 Nov 2022, 21:31
It's probably a problem with compressing the zip.
Because the file you attached cannot be opened in the editor.
I extracted the zip and found a file named __weather_4.png. which is the file that is causing the problem that it cannot be unpacked with program watchfac's editor.
I changed the name to weather_4.png compress again
Test sync to GTR3 can sync normally.
File Fixed and compress again :
Watch_face.zip
(114.51 KiB) Downloaded 175 times
roigreenberg
When I first packed it, there was an error with this file, so I changed the file and added it again, and got no more errors. apparently, it wasn't entirely true..
Jel
Post by Jel »
SashaCX75 wrote: 02 Nov 2022, 18:51
Thanks for your comments. Would be interested in your testing results.
Just saw, that the var sec definition after definition of animDelay is not necesserry, because it's defined a bit later ( where needed ), again ;) .
Jel
I would also reset animAngle inside the timer code with a large value of the animAngle variable and calculate startSec again. It's just that the timer usually does not work very accurately, and with a long display, this inaccuracy can accumulate.
Also I would change the code
              pos_x: 466 / 2 - second_posX,
              pos_y: 466 / 2 - second_posY,
              center_x: second_centerX,
              center_y: second_posX,
And the variables themselves set at the beginning. Of course, this will not affect the operation of the code, but it will be clearer to other users where these values ​​​​came from.
Not sure if you need to change the onDestory() section. The timer will still be stopped in the pause_call function. In addition, the specification does not say that the timer must be stopped.
You also have a newer version of the operating system and it seems that the typo in the function name has already been corrected and it is better to write onDestroy () instead of onDestory ().
I think you have a compact and descriptive code. Similar code that I once used, although it did the same thing, but was not so neat.
kwakykwaky1
Has thanked: 8 times
Post by kwakykwaky1 »
Hello, I have a new Gtr4 and in the watch face editor 5 application, after uploading, ADO does not appear, please advise. Thanks
Jel
Post by Jel »
Hello kwakykwaky1, you have to use V 5.0.1, provided by SashaCX75 https://www.dropbox.com/s/ssp9evw02krd0 ... 1.zip?dl=0
Jel
Post by Jel »
Hello SashaCX75 , I have changed the code for more flexibility and better understanding, but reseting the animAngle inside of the timer, I did'nt got to work. Thx for finding the typo.
            // SMOOTH SECONDS Definition
            let second_centerX = 233;
            let second_centerY = 233;
            let second_posX = 8;
            let second_posY = 223;
            var second_path = "0005.png";
    		let sec_pointer;
    		let clock_timer;
            const deviceInfo = hmSetting.getDeviceInfo();
			// SMOOTH SECONDS Definition End
              x: 0,
              y: 0,
              w: deviceInfo.width,
              h: deviceInfo.height,
              pos_x: deviceInfo.width / 2 - second_posX,
              pos_y: deviceInfo.height / 2 - second_posY,
              center_y: second_centerY,
              src: second_path,
              angle: 0,
Jel wrote: 04 Nov 2022, 21:19
I think it should be something like this
                        if(animAngle > 30)
                            animAngle == 0;
                            startSec = now.second*6;
But this will probably only be relevant if the second hand is displayed in AOD mode. In normal mode, the screen is turned on for a short time so that possible discrepancies in the readings become noticeable.
kwakykwaky1
Jel wrote: 04 Nov 2022, 21:12
Hello @kwakykwaky1, you have to use V 5.0.1, provided by @SashaCX75 https://www.dropbox.com/s/ssp9evw02krd0 ... 1.zip?dl=0
Thank you for the information :-)
Jel
Post by Jel »
Hello SashaCX75 , many thanks for all of your input. It took a while to think about the possible discrepancies. I think, I've found a solution. I changed away from calculating the progress by steps per "frames per second" to using "getMilliseconds()" inside of the timer. May, you can give it a try. Here is my final code example :
            // Smooth Seconds
            //   second_posX: 8,
            // take values from above. The 8 and 223 frome above, too.
            let second_path = "0005.png";
    	    let sec_pointer;
    	    let clock_timer;
	    let animAngle = 0;
            let animDelay = 0;
            const animRepeat = 1000/animFps;                // then execute every <animRepeat>ms
              x: 0,
              y: 0,
              src: second_path,
              angle: 0,
            const now = hmSensor.createSensor(hmSensor.id.TIME);
                            animAngle = (now.second*6) + (((now.utc % 1000)/1000)*6);
                            sec_pointer.setProperty(hmUI.prop.ANGLE, animAngle);
Users browsing this forum: Anderson08 and 2 guests
