Huawei watchface extractor
Reglas del Foro
Responder
Hazzing
Contactar:
Mensaje por Hazzing »
Hi.
I found some pretty need watchfaces for Huawei GT3, but I have a Amazfit GT3 Pro.
How can I extract contents from a *.hwt file for use in SashaCX75 editor?
Hazzing
Avatar de Usuario
Has thanked: 438 times
Been thanked: 2141 times
Contactar:
Mensaje por asoo »
Hazzing escribió: 10 Oct 2022, 19:47
Hi.
Hazzing
SashaCX75 editor use for edit " (Huami Amazfit ) GTR 3, GTR 3 Pro, GTS 3, T-Rex 2, GTR 4, GTS 4 Mini, Amazfit Band 7 (not to be confused with Mi Band 7)".
Not for use with HUAWEI
if you use HUAWEI try to see this :
viewtopic.php?t=1005
Hazzing
Contactar:
asoo ....no, I was not too clear....I want to extract the content (png files) from the Huawei and use them to create a watchface for Amazfit GT3 Pro
Avatar de Usuario
Contactar:
Mensaje por asoo »
Hazzing escribió: 11 Oct 2022, 14:57
@asoo ....no, I was not too clear....I want to extract the content (png files) from the Huawei and use them to create a watchface for Amazfit GT3 Pro
Sorry in the UNPACK tool of Huawei
I don't know about it either.
Lattenknaller
Has thanked: 62 times
Been thanked: 167 times
Contactar:
Mensaje por Lattenknaller »
you can try to rename .hwt in .zip and then extract
Hazzing
Contactar:
Lattenknaller ....oh, I've done that.....and you don't need to rename the file....all I get is a *.watchface file and a *.xml file and 2 preview png's.....I somehow need to extract the *.watchfile
Lattenknaller
Contactar:
Rename the . Watchfile in . Zip
It‘s a try
Hazzing
Contactar:
Lattenknaller ....it does not work either....
Avatar de Usuario
Contactar:
Mensaje por asoo »
I found program extract file "com.huawei.watchface" in 4pda
https://4pda.to/forum/index.php?showtop ... ry98008683
Thank owner for this program
I tested program can unpack normal . ( Test with watchface Huawei GT3 )
Mirror :
HuaweiWatchfaceExtractor-1.0.1.zip
(80.32 KiB) Descargado 1025 veces
Código: Seleccionar todo
command line to use :
Usage: HuaweiWatchFaceExtractor input [outputDir]
        input     *.hwt or com.huawei.watchface file
        outputDir optional output directory for extracted images. Defaults to <input>_extra
If I'm not mistaken, the program needs a java runtime.
Please install java runtime before use.
https://www.java.com/en/download/manual.jsp
Hazzing
Contactar:
asoo ....wow....thank you, but I'm not quite sure how to use the program.
It says, that you can drag and drop on the exe file, but I get nothing.
How did you get files extracted?
Avatar de Usuario
Contactar:
Mensaje por asoo »
Hazzing escribió: 13 Oct 2022, 14:27
@asoo ....wow....thank you, but I'm not quite sure how to use the program.
You installed java runtime or not ? if you do not install java runtime , program will not work .
you can see java runtime in this link :
I tried the program it work normal ( you can drag and drop or go to run on dos (CMD ) )
This picture in spoiler show the program work normal.
Imagen
Avatar de Usuario
Been thanked: 1044 times
Contactar:
Mensaje por SashaCX75 »
As far as I know, Huawei watch faces can be created in the usual form and in encrypted form. If the author decided to encrypt his watch face, then it will not work to extract resources from it. Most of the new watch faces are created in encrypted form and therefore it is impossible to extract resources from them. But I had little to do with Huawei dials, so I could be wrong.
Hazzing
Contactar:
asoo ....somehow I got it working, but as SashaCX75 says.....some files can be encrypted. I tried two different files....one worked and one didn't......
Responder
Volver a “Watchfaces tools (discussion)”
¿Quién está conectado?
