• Administrador
Regras do fórum
Avatar do usuário
Registrado em: 26 Out 2019, 15:18
Contato:
Mensagem por SashaCX75 »
Imagem
Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
Editado pela última vez por SashaCX75 em 01 Jun 2022, 07:19, em um total de 32 vezes.
seethebridges
Registrado em: 11 Jan 2022, 23:13
Contato:
Mensagem por seethebridges »
Hi there! Been trying to read through this thread in its entirety and understand getting started making a watchface for my GTS2. I've been poking around in the editor, but i just wanted to clarify the Z height issue. There is no way to specify Z order for elements other than those that are pre-populated there already right? Like for example, Im working on porting a watchface over from Pebbly/Fitbit, but to get the effects across correctly, I need the Date and time layers to both come above the weather image progression layer.
I cant find any way to adjust those elements, and it doesnt appear that its as simple as editing the json to have the weather section physically sooner in that config. Any advice as for where I should even begin poking around to get that kind of config option?
Or would I be better off attempting to get access to the official Zepp watchface editor since it looks like that tool has actual layer configurability. By the look of it, it only has support for the GTS3 now though? Im just feeling kinda lost at this point.
Avatar do usuário
Contato:
seethebridges
In the editor, you can change the order of the activity and atmosphere elements. The date is always displayed below these items. Time is always displayed above these elements.
sirantoninyc
Registrado em: 05 Jan 2022, 06:13
Contato:
Mensagem por sirantoninyc »
I customized an analog watch face but I cannot get the second hand to move during normal display. I searched the forum but I didn't find a solution, I also looked at the code of another watch where the second hand does move, my settings seem identical.
Imagem
Imagem
Secondly, I see the air pressure (barometer) in the preview of the editor, which I added in AOD above the 6 of the watch face, however the numbers do not display on my watch after installing the bin file. I see the hPa image I made and I can see the barometer under barometer when I swipe left but, the numbers do not display on my watch face.
Imagem
Imagem
Lastly, I cannot find where, under weather, those multiple weather images are being entered or where to adjust the coordinates.
Thanks,
Anthony
seethebridges
Contato:
SashaCX75 escreveu: 12 Jan 2022, 16:58
@seethebridges
Is this a hardcoded limitation of the watch OS? Or is that possible for me to go in and change somewhere and just a limitation on your software's interface?
Farsighted
Registrado em: 13 Jan 2022, 20:02
Contato:
Mensagem por Farsighted »
When I run AmazFit WatchFace editor 2, half of the window is outside of my screen. The maximize button is missing. The window has a fixed size and can not be resized.
I'm using Windows 10, resolution 1920x1080 with 175 dpi on a 52 inch screen.
Can you add a maximize button and make the window resizable ?
Can you make AmazFit WatchFace editor 2 compatible with different screen resolutions and DPIs ?
What configuration are you using ? What are the system requirements ?
murmilega
Registrado em: 23 Abr 2021, 22:19
Contato:
Mensagem por murmilega »
Hello, thank you very much for your great work, I would like to make a sphere with a moon phase but I can't find how to do it, would you know how to guide me on how to do it? Thank you very much
Avatar do usuário
Contato:
sirantoninyc escreveu: 13 Jan 2022, 06:54
In the screenshots, all settings for the second hand look normal.
On the GTR 2, the atmospheric pressure starts to be displayed on the dial only after the compass is entered in the widgets (if I remember correctly). But you have something like a T-Rex Pro and I'm not sure if the barometric pressure display works on this watch.
Weather icons are edited in Atmosphere > Weather > Image Set.
Avatar do usuário
Contato:
seethebridges escreveu: 14 Jan 2022, 08:54
I don't know if this is a limitation of the watch firmware or the utility used in the editor to build bin files. As far as I know, the position of these elements could not be changed even in the Huami editor, maybe something has changed now.
Avatar do usuário
Contato:
murmilega escreveu: 14 Jan 2022, 14:15
There is no such possibility. Such functions seem to be in some built-in watch faces, but this cannot be done in third-party watch faces.
sirantoninyc
Contato:
SashaCX75 escreveu: 14 Jan 2022, 15:49
Thanks Sasha for your quick reply! Also, thanks for this amazing editor! I'm having a lot of fun editing my favorite watch face with it!
I'm not sure why the second hand does not move either, but I'm glad the settings look correct.
I do have a T Rex Pro. I noticed the barometer displays pressure but is searching for GPS and height. That could possibly be the issue.
THANKS for the weather image location, in English it's Atmosphere - Weather - Image Process, I wanted to adjust the location a little bit so that the high and low temperature isn't as obscured.
Thanks again!!!
Anthony
caglargoru
Registrado em: 19 Abr 2020, 09:07
Contato:
Mensagem por caglargoru »
Is there anything like a guide or sth about the program? (AmazFit WatchFace editor 2 for Windows)
MaPo80
Registrado em: 06 Fev 2022, 08:57
Contato:
Mensagem por MaPo80 »
there is the same issue with the latest version (11.1). Version 6.1 is working but it is a little bit old version.
Would it be possible to fix it in next update?
Thanks.
theleon escreveu: 10 Jul 2021, 15:41
Downloaded the latest version, and when trying to open any GTR 2 watchface, I get the following errors:
- "PNG files go out of order or some of the files are missing"
and right after:
- "Invalid JSON file. ... Cannot deserialize current JSON arary into type 'GTR_Watch_face.ImageW'"
While the errors can be clicked away, the preview stays blank. Any idea what I'm doing wrong?
It's my first time using this editor.
EDIT: Nevermind, got it to work. Had downloaded the "GTR (GTS, T-Rex) to GTR2 (GTS 2, T-Rex Pro) Converter & Editor" instead of the Version 5.0... Didn't realize you could click on the Version 5.0, woops.
Superwitschi
Registrado em: 30 Jun 2020, 03:11
Has thanked: 8 times
Contato:
Mensagem por Superwitschi »
Can we add in GTR 2 also smooth second movement? If yes what codes i have to take and where i have to change codes?
Avatar do usuário
Contato:
I don't think this is possible on the GTR 2.
Andrei_Richea
Registrado em: 30 Set 2021, 06:21
Contato:
Mensagem por Andrei_Richea »
@ SashaCX75 . Hello .Is there any possibility of being able to add fonts to the program Amazfit Watchface editor 2 through a tab or something similar. So you can play with the numbers in the circle system font. I would appreciate it if you could do this. Or tell us how we can do it. Greetings and thanks for the great work.
don1yoor
Registrado em: 02 Fev 2022, 13:57
Contato:
Mensagem por don1yoor »
Hello guys. How to unpack .bin file. I cant unpack. When i click unpack, there opening site www.java/download please help me. I used last version Watchface tools
Darkstalix
Registrado em: 28 Mar 2021, 20:16
Contato:
Mensagem por Darkstalix »
Is this supposed to convert gts to gts2 guys? i know sasha stopped developing this and i was wondering if anyone is up to date?
I unpacked a GTS WF and then packed it to GTS2 WF and it actually somehow worked almost, just out of curiosity i tried.
So far only the battery numbers are missing and the percentage icon it had. Looks like everything else works?
However whenever i try to unpack a GTS 2 WF (i tried like 6 different from this site)i always get an error of png files missing or order being wrong, i did that just in case i could find the battery code and paste then edit on the WF i want to pack.
Anyone got any clues?
IL_DEMONICO
Registrado em: 19 Fev 2021, 10:26
Contato:
Mensagem por IL_DEMONICO »
Hello to everyone, is there a way to apply image sequence to hours?
i designed a watchface in which i'd like to put a different image for every hour, from 1 to 12. Is there a way to set image sequence with the same behavior of months, or battery for example?
thanks in advance
Steve2fit
Registrado em: 25 Set 2020, 11:41
Contato:
Mensagem por Steve2fit »
I am running Version 7.3. I am not sure why I am getting double images when I do a Refresh Preview. I have no idea how to clean this up and it does get carried over to the watch.
This only appears when I do the Refresh Preview, no other time.
Any help would be appreciated.
Imagem
Avatar do usuário
Been thanked: 2122 times
Mensagem por asoo »
Steve2fit escreveu: 23 Mai 2022, 19:32
Imagem
If you need help fixing the issue . I recommen you to attach the watchface you are having problems with, or at least .json of that work.
Just the picture that you show, it's hard to predict what that issue.
Steve2fit
Contato:
I have attached the file for you to review.
Anexos
orange_packed-516597-e18cd6d1af_packed_packed.zip
(1.3 KiB) Baixado 402 vezes
Avatar do usuário
Mensagem por asoo »
Steve2fit escreveu: 24 Mai 2022, 12:43
Imagem
Your issue is steps image index start at 0047.png . I think that file is preview picture.
if steps show number 0 it will be show preview picture. so I think that's the problem.
Steve2fit
Contato:
Thank you!
Mayfly
Registrado em: 08 Jun 2022, 08:29
Contato:
Mensagem por Mayfly »
IT CONTAINS MALAWARE VIRUS!!!
Avatar do usuário
Registrado em: 22 Mar 2018, 10:00
Has thanked: 1162 times
Been thanked: 278 times
Contato:
Mensagem por GIK-Team »
Mayfly escreveu: 08 Jun 2022, 16:50
There are no viruses
Responder
Quem está online
Usuários navegando neste fórum: Nenhum usuário registrado e 2 visitantes
