localStorage.setItem('examineType', '2')If you get issues with the editor again, run the code above again.
Original post on 4pda (Russian)
localStorage.setItem('examineType', '2')The editor isnt working properly and i can make watch faces the topic u send has no realtion with it please help me fix the errors
The topic I am linking to is about the editor you mentioned and it discusses the problem that is being solved. Provide more clarity by pointing out the errors you are experiencing.Kakashi-o-o- wrote: 10 Dec 2021, 12:54The editor isnt working properly and i can make watch faces the topic u send has no realtion with it please help me fix the errors
in the huami awtch face editor i cant select watch name and versionGIK-Team wrote: 10 Dec 2021, 13:10The topic I am linking to is about the editor you mentioned and it discusses the problem that is being solved. Provide more clarity by pointing out the errors you are experiencing.Kakashi-o-o- wrote: 10 Dec 2021, 12:54The editor isnt working properly and i can make watch faces the topic u send has no realtion with it please help me fix the errors
This is discussed here: viewtopic.php?t=2671Kakashi-o-o- wrote: 10 Dec 2021, 13:29in the huami awtch face editor i cant select watch name and versionGIK-Team wrote: 10 Dec 2021, 13:10The topic I am linking to is about the editor you mentioned and it discusses the problem that is being solved. Provide more clarity by pointing out the errors you are experiencing.Kakashi-o-o- wrote: 10 Dec 2021, 12:54
I got this error in Chromesk1nzz wrote: 25 Jun 2021, 10:12Make sure you reloaded the page after running this code.jazzrock71 wrote: 23 Jun 2021, 13:14I tried to paste that line into console, but it didn't work.... anyone can help me?
undefinedCode: Select all
localStorage.setItem('wf_examineType', '2')Bumping this thread because Ive also run into this. have you found anything else regarding it? I cant export GTS or GTR 2 faces. Its always the same error complaining about the encoder script. I tried looking around for an archived page of the tool or SOMETHING, but I came up empty.istanbulls wrote: 10 Jan 2022, 15:12Hi All,
I made a few watch faces for the T-Rex, I've been enjoying using them. I'm having a problem after the new year, I can't export.
I get the error "export failed encoder script file not exists".
Does anyone know about this issue. Am I the only one having this problem?!!
edit:
I did a test for the gts2 mini, it's fine, but the problem persists with the T-Rex.
Zap is a zip format you can uncompress this file by use winrar , or winzip after you uncompress you can found your watchface inside that file.FeRu wrote: 13 Jan 2022, 22:53Hello. Can somebody tell me because I tried today port my GTR2 face to GTR3 PRO by using this Huami editor (sometimes it's pissed me off) but after I created finaly my first face with this tool it wil export my WF as *.zap file and I don't know this is ok and how use this....
asoo wrote: 14 Jan 2022, 02:40Zap is a zip format you can uncompress this file by use winrar , or winzip after you uncompress you can found your watchface inside that file.FeRu wrote: 13 Jan 2022, 22:53Hello. Can somebody tell me because I tried today port my GTR2 face to GTR3 PRO by using this Huami editor (sometimes it's pissed me off) but after I created finaly my first face with this tool it wil export my WF as *.zap file and I don't know this is ok and how use this....
Another Thing is that i am not able to enter developer mode in zepp app. This option is just not available.V4.4 (August 2, 2021)
New Features
Adds display of update logs to help pages
Supports multiple languages on help pages
Adds 480480 and 390450 resolutions to upload review of GT2 series
Adds the feature of copying editable components
Optimized Features
Optimizes the preview of editable components and image progress
Allows the BIN file text of an exported watch face to be automatically named after the created project
I managed it by myself.FeRu wrote: 15 Jan 2022, 21:09I noticed something and can you confirm that Huami WF editor compress png files for watchface and they have worse quality than original? Because When I install WF on my GTR3 Pro all elements are little blurred even when I upload the best possible png quality images in that resolution.
Also how use pointers in this editor? I used the same parameters as I used in SashaCX75 editor and it's not working properly![]()
Anyway I can't wait for SashaCX75 editor because after few days using this editor I can say that It's disabled![]()
So by the looks of it, you dont even need the js console command as far as I can tell. Just access the editor, login with your Zepp account, and you can make and export watch faces.
