Search found 5 matches
Return
by SashaCX75
07 Jan 2022, 14:16
Jump to forum
Jump to topic
- Amazfit Bip 5 ...
by SashaCX75
11 Jan 2022, 18:47
Jump to forum
Jump to topic
Dema
No, this cannot be changed for a set of images. To change this for circular or linear progress you need to open the watch face, in the "watchface" folder open the "index.js" file. In this file, find the line let progressHeartRate = (valueHeartRate - 71) / (targetHeartRate - 71); and in it ...
by FeRu
11 Jan 2022, 19:50
Jump to forum
Jump to topic
@SashaCX75
Thank you very much!
I have another question to you, if I can!
A user that download my dials, just wrote me that have a problem with two version of the same watchface.
Practically, i did a dial in different versions, analog and digital and obviously i used the same base.
The user told ...
by Mazaias
14 Jan 2022, 11:25
Jump to forum
Jump to topic
Thank you so much @SashaCX75. I know this should be simple, but can anyone tell me how I actually install the .zip file on my watch after I pack it? Thank you!
To test the face on the watch, it is faster to rename the zip file to bin and copy it to the memory of the mobile. Then the bin is ...
by asoo
17 Jan 2022, 08:29
Jump to forum
Jump to topic
Is there any solution how to make that pointer in heart rate section or any other section to be above image progres (I mean to have higher priority of showing)?
Because right now in some WFs when I want add pointer to Heart rate progress in huami editor or in this editor pointer is hiding below ...
