La ricerca ha trovato 12 risultati
- 17 dic 2019, 13:54
- Jump to forum
- Jump to topic
Re: GTS Watchface Tool - beta v.0.1
Why not release the tools on the "normal" internet? Not everybody wants to have to use Telegram.
- 04 gen 2020, 09:00
- Jump to forum
- Jump to topic
The best watchface editing and creation program that also works with GTS at this link:
viewtopic.php?f=29&t=1076&start=10
- 07 mar 2021, 10:37
- Jump to forum
- Jump to topic
https://i.postimg.cc/g28GYVds/en.gif
Not all dials can be unpacked ...
- 21 mar 2021, 14:18
- Jump to forum
- Jump to topic
Salut,
1) Use "unpack compressed .bin " button and choose the bin file you would like to modify
2) This will create a new folder in "Watch_face" folder with png and json files
3) Replace english png files by french ones and adjust positions if needed (this will modifiy json file)
4) Save json file ...
- 08 giu 2021, 14:39
- Jump to forum
- Jump to topic
The size of the system font should not be more than 47, it can cause an infinite reboot watch.
- 12 lug 2021, 13:32
- Jump to forum
- Jump to topic
Re: Bip U / GTS 2 mini watchface editor
Evening all,
(first post)... Just a quick one to let people know the original localStorage command is missing a trailing ';'. If posted in the chrome console (and chrome derivative browsers), the command isn't executed.
I noticed that if I returned to the https://dev.huami.com/#/home page, the ...
- 12 lug 2021, 14:26
- Jump to forum
- Jump to topic
- 29 ago 2021, 19:58
- Jump to forum
- Jump to topic
evileyes
The first file must be a background or preview.
This watch face is made for Zepp E Circle and not for Trex Pro.
- 10 dic 2021, 00:03
- Jump to forum
- Jump to topic
You have to go there now : viewtopic.php?t=1888
Don't hesitate to read the 15 pages of thos post...
That's this way I could make watchfaces for GTS2.
Best regards.
- 11 dic 2021, 09:05
- Jump to forum
- Jump to topic
amazneo
1. Judging by your questions, you are using the GTR47 / GTS watch face editor or the GTR47 / GTS to GTR2 / GTS2 dial converter (I do not recommend using it). The program for GTR2 / GTS2 is being discussed here.
2. If you are editing an existing watch face, then the procedure is correct ...
- 12 dic 2021, 21:26
- Jump to forum
- Jump to topic
Re: Huami watchface editor
This code works in the new editor
Try to sign in again if it doesn't work
Codice: Seleziona tutto
localStorage.setItem('wf_examineType', '2')- 18 dic 2021, 09:42
- Jump to forum
- Jump to topic
Hello, I am a bit confused about which tool to use to create watch faces for the GTS?
I started out using this tool:
https://amazfitwatchfaces.com/forum/viewtopic.php?p=8844#p8844
But, then was told that I should be using this tool ...
