Been thanked: 1029 times
Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
cjlin
Post by cjlin »
where can i get the AmazFit WatchFace editor 2 help or tutorial ?
thank you.
dimi_tris
Post by dimi_tris »
cjlin wrote: 07 Sep 2021, 04:57
thank you.
+1
HakunaMatmata
Post by HakunaMatmata »
Thanks for your work SashaCX75 !
Really appreciate.
One question :
I was trying to make a custom watchface and wanted to have a vertical progress bar for seconds.
Is it possible?
I first tried to have any progress bar vertical but did not find the trick.
It seems only proposed horizontal and when I tried to edit json directly it gets revert when compiled in BIN.
How to manually edit json?
Then I wanted to try to add an object progress bar to digital seconds but same problem with json being replaced before compilation.
Thanks in advance,
regards
HakunaMatmata
The vertical progress bar can only be implemented using a set of pictures for this.
cjlin
Here you can see the instructions for the GTR Watch Faces Editor. This editor is different, but the way it works is very similar.
Julien
Post by Julien »
Dear SashaCX75 I've been working on porting the .bin unpacker for the GTS 2 Mini. It's not done yet, and I've contacted bigdigital who seems to have worked on this too.
I was wondering if you can guide me through the required step to enable compatibility with your app, right now I'm working on https://github.com/Tnxec2/py_amazfit_tools/
neFAST
I have not seen a working utility for unpacking the GTS 2 Mini dials, so it's hard for me to say anything definite. If @bigdigital adds such a functional to his utility, then there will probably be a separate argument for packing it into the GTS 2 Mini format. My editor does not have the ability to change the unpacking utility startup arguments, but you can do this by editing the Settings.json file.
As far as I know, the structure and capabilities of the GTS 2 Mini dials differ from the GTS 2, so if my editor can work with such dials, then only with some of them.
HakunaMatmata
thanks you for your quick answer.
It will be difficult to get what I was trying then (vertically fill minutes figures with a 50% transparency progressbar)
i'll redesign differently then.
milanior
Post by milanior »
great app Sasha, thank you
Julien
Post by Julien »
SashaCX75 wrote: 08 Sep 2021, 18:34
@neFAST
I've pushed the sum of bigdigital and my work here: https://github.com/JulienMaille/py_amaz ... /tree/GTS2
This fork is able to parse bin files from GTS 2 mini, read images and partially match the parameters to their definition. Anyone who can help will be welcome. I'll post updates here if you want.
Version 7.2
shinai
Post by shinai »
Hello!
At first: Thank you SashaCX75 for the editor!
It is a really great and intuitive app!!! But I need some help with it.
After unpacking some GMT-style watchface the initial values of "ImagesCount" of DigitalClock Hours has been reduced to 10.
I tried to change some values, manually edit this value or whatever, this value allways changed to 10.
It remains after packing to .bin too. The preview shows this immediately - the 24hour circle of GMT circle rotates only in 10 positions instead of needed correct 24.
Please help me to solve this bug of GTR2 faces.
Thank you very much!!!
Sinai
This cannot be done in the editor.
You can edit the json file in a text editor, then create a bin file in the editor. Not sure exactly what you want, but I think you need to still change the parameter "DisplayFormAnalog": true
shinai
Post by shinai »
Only want to change background and add other picture files to watchface.
The other values I don´t want exactly to change, but they are not remain as origin.
I try this, maybe it will solve the problem.
Thank for your support!
HakunaMatmata
Thanks again for the tool and the answers here, I still have a few questions please :
- I saw in the manual you send the ability to create shortcut but did not find it in the program, is it scheduled or is it incompatible with GTR2?
- I could not find a way to display on idle screen the editable widgets, there is a native watchface that seems to do so thought (but I am not able to find the bin so I can see how it is written), is there a setting or a method I'm missing here?
- Finally, is there a way to have a progression line/picture for seconds (i'd like to create something graphical)
Thanks in advance,
almost done with my first watchface and will soon release it on the site !
HakunaMatmata
Shortcuts on GTR2 don't work.
AOD does not support editable zones.
For time, you can add circular progress, but it does not work correctly, so I did not add it to the editor. I have not tested the linear progress for time, but I think it does not work either.
shinai
Post by shinai »
I have to say a BIG THANK YOU to SashaCX75! Your advice was great! Simple and clever!
I was totally dumb, I tried to upload the same old bins on GTR2 instead of the correct new one :P
So Your solution already worked! I´m so happy!
So THX again & have a nice day!
Julien
Post by Julien »
SashaCX75 I'm looking at what's possible in Huami editor and what can be found in Zepp watchfaces.
Looking at the .bin file, it seems they are able to set different coordinates for units, ten, hundred, thousands digits. However I can't find how to do this in the official editor (the only one available for the Mini)
So my question is: is it the same case for GTS/GTS2? independent coordinates position is possible in your editor but not in the official one?
Thanks in advance
On the GTS, you can set independent coordinates for units and tens, but only for time. This is not possible on the GTS2.
On the GTS2 mini, I think there is no such possibility. To display data, there is such a parameter as "alignment", so only the coordinates of the rectangle where the data should be placed are set and there are no separate coordinates for units and tens.
FeRu
Has thanked: 14 times
Been thanked: 8 times
Post by FeRu »
Hello guys....I'm learning to edit and convert watchfaces with this awesome software, but I have problem... After porting and editing RZ223 mod by asoo watchface from GTR47 to GTR2 with Amazfit Watchface Editor GTR to GTR2 I want edit and add more features with Amazfit Watchface Editor 2 7.2 but I cant uncompress bin file and it give me error with invalid json file and inf that png files must start with 0001, but older faces starts from 0000 :roll:
I'll try fix this problem with edit json, remove 0000 file but nothing works....
How can I fix this problem without remade watchface from scratch??
This is watchface that I want add AOD and few other things with newest Edtior 7.2
I will be really gratefull if someone with more experience can help me 8-)
https://amazfitwatchfaces.com/gtr/view/17964
Cheers.
rz223_zip-15485-a959407a31_PL_Custom_packed.bin
(474.79 KiB) Downloaded 183 times
rz223_zip-15485-a959407a31_2_Custom_packed.bin
(520.59 KiB) Downloaded 169 times
Has thanked: 414 times
Been thanked: 2073 times
FeRu wrote: 24 Sep 2021, 11:36
Hello guys....I'm learning to edit and convert watchfaces with this awesome software, but I have problem... After porting and editing RZ223 mod by @asoo watchface from GTR47 to GTR2 with Amazfit Watchface Editor GTR to GTR2 I want edit and add more features with Amazfit Watchface Editor 2 7.2 but I cant uncompress bin file and it give me error with invalid json file and inf that png files must start with 0001, but older faces starts from 0000 :roll:
Cheers.
If you're going to create it in real GTR2 format, you can't use .json derived from the conversion. You must rebuild it by use program "Amazfit Watchface Editor 2", using the resources obtained by extracting the files converted.
What you need to solve before use resources
- rename the file to start from 0001
- Added weather icon to have 29 icons as standard of GTR2.
( The weather icon obtained by converting files from GTR will only have 26 icons )
FeRu
Post by FeRu »
Ohhhh ok I get it... Thanks asoo... So there is no simple and fast solution and I need to rebuild skin in Amazfit WF Editor 2 anyway....
FeRu wrote: 24 Sep 2021, 13:22
Ohhhh ok I get it... Thanks @asoo... So there is no simple and fast solution and I need to rebuild skin in Amazfit WF Editor 2 anyway....
I made it for real format GTR2 ready , you can modify from this
https://amazfitwatchfaces.com/gtr/view/17999
Julien
Post by Julien »
SashaCX75 wrote: 24 Sep 2021, 06:18
This is not possible in the official editor, but there are official Zepp watchfaces that do use independent coordinates like this one:
This is confirmed when dissassembling
And the json for steps looks like 5 times the digit with a different Y offset:
- 3 (1A): 57 bytes
-     1 ( 8): 103 67
-     2 (12): 9 bytes
-         1 ( 8): 29 1D
-         2 (10): 59 3B
-         3 (18): 134 86
-         4 (20): 10  A
-     3 (1A): 9 bytes
-         1 ( 8): 29 1D
-         2 (10): 72 48
-         3 (18): 134 86
-         4 (20): 10  A
-     4 (22): 9 bytes
-         1 ( 8): 29 1D
-         2 (10): 85 55
-         3 (18): 134 86
-         4 (20): 10  A
-     5 (2A): 9 bytes
-         1 ( 8): 29 1D
-         2 (10): 98 62
-         3 (18): 134 86
-         4 (20): 10  A
-     6 (32): 9 bytes
-         1 ( 8): 29 1D
-         2 (10): 111 6F
-         3 (18): 134 86
-         4 (20): 10  A
neFAST
It is difficult to judge from the screenshot, but you seem to be right, for GTS 2 Mini you can set independent coordinates for units, tens and hundreds. This makes it possible to display labels at an angle or in a circle with your own font.
GTS 2 has the ability to display dials from GTS, for this one byte is changed in the bin file header. If you come across a dial with a non-standard structure in the GTS 2 Mini, then pay attention to this, perhaps this is what the case.
Interesting dial, you can send the source bin file and what happened after unpacking. Curious to look at him.
Julien
Post by Julien »
I have attached the .bin file (original file name from Zepp cache folder)
I believe the GTS 2 Mini is rebranded Bip U++ and closer to Bip series than GTS/R series
You will see it has independent offset at least for steps, bpm, battery and kcal.
Header is similar to watchface created with the editor
468da72c923467e6ac1c2752a238a4b3.bin
(747.53 KiB) Downloaded 204 times
