a free website that can upload zip file and it will generate qrcode?
Discussions on other topics.
g-rex69
Post by g-rex69 »
is there a free website that you can upload zip file and it will generate qrcode
for people to download to the watch and install it on zepp app?
Or you have another method to share watchfaces without sending the zip file.
Thanx
frankh93
Has thanked: 24 times
Post by frankh93 »
You can check this guide viewtopic.php?t=3873 to make the qr uploading the zpk to sites like catbox.moe or pcloud, but basically you can generate the qrcodes for your watchfaces using any site that provides the direct link to the file, otherwise it won't work
Return to “Off-Topic”
