- 管理员
Date format is incorrectly displayed as month/day. [T-Rex 3 Pro]
版面规则
The date is displayed correctly in the watch face editor, including in the PNG preview. After installation on the watch, the date is displayed incorrectly, not in the European day/month format. What do I need to change?
Cheers
- 附件
mbmuch_spartan_v3_T_Rex_3_Pro_48mm.zip- (120.79 KiB) 已下载 86 次
- 来自: ͼͽ Thailand ͼͽ
- Has thanked: 420 time
- Been thanked: 2117 time
My country also uses the day-month format.
I tried installing your watch face on my Bip6, and it displayed the date format as day-month. I'm not sure if it's due to the T_Rex_3_Pro_48mm firmware or if there's a setting for changing the date format, which I'm not sure if the Trex 3pro 48mm has a menu to change the format.
But on the Bip6, you can change the date format.
Settings --> watchface & time ---> Date Format
Dude, you're right, I have that menu on my TRex3 Pro too. But tell me why it changed with this face? I haven't had any problems with the display before. But whatever. You've got the answer. Thanks a lot!
Cheers from Germany
Cheers from Germany
在线用户
正浏览此版面之用户: 没有注册用户 和 2 访客
