Date format is incorrectly displayed as month/day. [T-Rex 3 Pro]
Moderatori: asoo, Watchmens
mbmuch
Messaggio da mbmuch »
The date is displayed correctly in the watch face editor, including in the PNG preview. After installation on the watch, the date is displayed incorrectly, not in the European day/month format. What do I need to change?
Cheers
Allegati
mbmuch_spartan_v3_T_Rex_3_Pro_48mm.zip
(120.79 KiB) Scaricato 66 volte
Has thanked: 404 times
Been thanked: 2023 times
Messaggio da asoo »
mbmuch ha scritto: 10 mar 2026, 08:58
Cheers
My country also uses the day-month format.
I tried installing your watch face on my Bip6, and it displayed the date format as day-month. I'm not sure if it's due to the T_Rex_3_Pro_48mm firmware or if there's a setting for changing the date format, which I'm not sure if the Trex 3pro 48mm has a menu to change the format.
But on the Bip6, you can change the date format.
Settings --> watchface & time ---> Date Format
Images in the test.
mbmuch
Dude, you're right, I have that menu on my TRex3 Pro too. But tell me why it changed with this face? I haven't had any problems with the display before. But whatever. You've got the answer. Thanks a lot!
Cheers from Germany
