Port to Active 2 - Poppy_Thin & Virtu V2
ativirs
Has thanked: 9 times
Post by ativirs »
Can someone port these watchfaces for active 2?
The Balance ones are different in resolution and are not aligned properly on Active 2.
These are made by asoo https://amazfitwatchfaces.com/ucp/15485.
1.https://amazfitwatchfaces.com/balance/view/282
2.https://amazfitwatchfaces.com/balance/view/1554
Has thanked: 411 times
Been thanked: 2050 times
ativirs wrote: 20 Jun 2025, 11:28
I have said before, I will not convert watch faces from facer.io again, but the work you mentioned is my old work, so I will convert it for you. However, I does not have "Active_2", so I cannot verify anything. However, you can actually convert it yourself using the program
Download 💾📥
Virtu_V2_Active_2.zip
(246.92 KiB) Downloaded 75 times
Poppy_Thin_Active_2.zip
(920.11 KiB) Downloaded 62 times
ativirs
Post by ativirs »
Thanks for these
