Can someone port these watchfaces for active 2?
The Balance ones are different in resolution and are not aligned properly on Active 2.
These are made by asoo https://amazfitwatchfaces.com/ucp/15485.
1.https://amazfitwatchfaces.com/balance/view/282
2.https://amazfitwatchfaces.com/balance/view/1554
- Amministratore
Port to Active 2 - Poppy_Thin & Virtu V2
- Has thanked: 419 times
- Been thanked: 2110 times
I have said before, I will not convert watch faces from facer.io again, but the work you mentioned is my old work, so I will convert it for you. However, I does not have "Active_2", so I cannot verify anything. However, you can actually convert it yourself using the programativirs ha scritto: 20 giu 2025, 11:28Hello,
Download 💾📥
