Пошук дав 9 результатів
Return
Stas
11 липня 2025, 14:59
Jump to forum
Jump to topic
Re: AmazFaces for iOS [Support]
We’ve identified a problem with the Active 2 round device and the “Install watchface” option in app version 4.7.395.
The update (4.7.396) will be available for iOS devices within the next few days.
In the meantime, you can install the app using the QR code in developer mode.
If you need ...
rush2112
10 липня 2025, 19:20
Jump to forum
Jump to topic
Re: Amazfit watch face generator v3
Here's a quick tip: When creating icons on the Amazfit Watch Face Generator v3, simply click here and enter your text strings separated by commas after pressing Win + (dot) on your keyboard. Voilà! :)
Зображення
TRK88PL
11 липня 2025, 15:13
Jump to forum
Jump to topic
This is exactly the difference between my generator and some older solutions... Here, you can type anything and it will be generated. From what I’ve tested, Unicode should work too :) Either way, it's nice to see you're still checking what this generator can do and that someone is actually using it ...
ahmadjie80
16 жовтня 2025, 05:59
Jump to forum
Jump to topic
Re: HUAWEI BAND
Huawei Band 9, and wil work too on HB 8 and 10
20 травня 2025, 16:50
Jump to forum
Jump to topic
I will stop accepting requests and help to port watchface in all cases
Since I mainly use Balance, I would like to use this space to inform you about for my support for porting watchface from other systems to use with ZeppOS.
As you can see, I have ported interesting and quality dials from other systems to use with zeppos without making any money from them. However, I ...
20 червня 2025, 14:51
Jump to forum
Jump to topic
Re: Port to Active 2 - Poppy_Thin & Virtu V2
Can someone port these watchfaces for active 2?
The Balance ones are different in resolution and are not aligned properly on Active 2.
These are made by asoo https://amazfitwatchfaces.com/ucp/15485 .
1. https://amazfitwatchfaces.com/balance/view/282
2. https://amazfitwatchfaces.com ...
24 червня 2025, 00:08
Jump to forum
Jump to topic
Re: Port to Active 2 - Elegance by StarScreaM
My mistake. I forgot I reached out to the author and he supplied a fix. Here's the working 12 hour version.
https://mega.nz/file/a0UyDCzD#KGvpQqJtT ... -I3hjlKbCI
24 червня 2025, 12:51
Jump to forum
Jump to topic
Just a word of caution, it uses a lot of battery, at least on my Active 2, probably because of the animation. I might look into making some adjustments to see if I can make any improvements in battery life.
