Conversion from Balance to GTR3
Pox87
- Has thanked: 27 times
Hello everyone,
Will someone be so kind to convert this amazing Lattenknaller wf from balance to GTR 3?
https://amazfitwatchfaces.com/balance/view/4272
Best regards
Best regards
- Has thanked: 130 times
- Been thanked: 19 times
You can typically install watchfaces for other models even with different resolutions usually with good results.
I've installed GTR4 and Balance watchfaces on my Active 2.
I download the .zip files on my phone then install them with the Notify for Amazfit app. (On Android, you have to clear data/cache for the Zepp app -- or just uninstall it then reinstall it when finished -- first because both apps can't run at the same time.)
Pox87
You are right but unfortunately balance install directly on GTR will not fit as have version 2 technology so result as no clock hands and no proper layout.
If properly convert instead Will fit but i cannot convert from my side unfortunately
Did you try converting it with the SashaCX75 watchface tool?
GTR 3 is ZeppOS 1.0 while Balance is 4.0.
It may not be possible without extensive work due to the ZeppOS differences but someone who is more advanced would have a better idea why.
- SashaCX75
- Has thanked: 13 times
- Been thanked: 1036 times
Almost all watch faces are written in API 1. Therefore, there are no problems when launching them on different models. But sometimes watch faces have widgets that do not work on older models. You can simply install the existing watch face and check whether it works or not. If it works normally, then you can try converting it.taw_bip wrote: 16 Jun 2025, 11:41Did you try converting it with the SashaCX75 watchface tool?
Users browsing this forum: No registered users and 12 guests
