I'm using Facemaker software, and I can't import an existing watch face from an existing GTR4 to adapt it and convert it to my watch, which is a T-Rex 3. I get the impression that Facemaker can only open BIN files. Is there a way to convert my ZIP file to BIN so I can open it in Facemaker? Thanks for your help.
Mike
problem importing a gtr4 zip into facemaker
mike413muo3
- Has thanked: 418 times
- Been thanked: 2101 times
if I remember correctly, The Facemaker, is a paid program, so if you have purchased his program, I suggest you ask the program owner, you should get the correct answer.mike413muo3 wrote: 03 Jun 2025, 05:27Hello,
Mike
https://facemaker.pt/
mike413muo3
I asked the question but unfortunately I didn't get an answer...
If that's what you said, I would like to express my condolences to you.mike413muo3 wrote: 03 Jun 2025, 10:44I asked the question but unfortunately I didn't get an answer...
ฺBut I can't answer either, because I don't use the editor you asked about to create the watch face of the device using zeppOS.
Hopefully, have someone who uses that editor you talking about and can answer your question can help you.
Good luck.
- Has thanked: 130 times
- Been thanked: 19 times
If the original file did not originate from Facemaker, then most likely it will not import into Facemaker. The author has spoken a few times about incompatibility with code structure when people asked about importing watchfaces made with the SashaCX75 application or the Zepp online watchface tool.
It sounds like it will have to be made from scratch unless you can export the images somehow.
