problem importing a gtr4 zip into facemaker
Moderatori: asoo, Watchmens
mike413muo3
Messaggio da mike413muo3 »
I'm using Facemaker software, and I can't import an existing watch face from an existing GTR4 to adapt it and convert it to my watch, which is a T-Rex 3. I get the impression that Facemaker can only open BIN files. Is there a way to convert my ZIP file to BIN so I can open it in Facemaker? Thanks for your help.
Mike
Has thanked: 418 times
Been thanked: 2101 times
Messaggio da asoo »
mike413muo3 ha scritto: 03 giu 2025, 05:27
Mike
if I remember correctly, The Facemaker, is a paid program, so if you have purchased his program, I suggest you ask the program owner, you should get the correct answer.
https://facemaker.pt/
mike413muo3
I asked the question but unfortunately I didn't get an answer...
Messaggio da asoo »
mike413muo3 ha scritto: 03 giu 2025, 10:44
If that's what you said, I would like to express my condolences to you.
ฺBut I can't answer either, because I don't use the editor you asked about to create the watch face of the device using zeppOS.
Hopefully, have someone who uses that editor you talking about and can answer your question can help you.
Good luck.
Has thanked: 130 times
Been thanked: 19 times
Messaggio da taw_bip »
If the original file did not originate from Facemaker, then most likely it will not import into Facemaker. The author has spoken a few times about incompatibility with code structure when people asked about importing watchfaces made with the SashaCX75 application or the Zepp online watchface tool.
It sounds like it will have to be made from scratch unless you can export the images somehow.
Torna a “Device discussion”
