Is image format for GTR/GTS 3/4 not Truevision_TGA (.tga) in fact?
Lilonu
Post by Lilonu »
Hi everybody (first post of mine here),
after playing and fiddling with watchface making on code level, I almost bricked my GTS-4 with inadvertingly feeding it an image in the wrong format (see here). With the (true) png images I used, the watchfaces did not install and so I examined the example images(.png) on the binary level and discovered that they in fact are Truevision_TGA images, non-compressed, indexed (or paletted), 255 color, origin left top.
With wrongly using a non-indexed, compressed (RLE) left bottom version I send, as mentioned, my watch into a boot loop, which I escaped only with luck later.
Before I make another test with a (I assume) correct tga: Anybody been there before?
Been thanked: 2120 times
I used to pack the dials using normal png, but didn't find any looping. The watch only shows the wrong color or not show image on screen (on GTR 3) , and you can delete it out normally
_________________
If you want to manipulate png used in ZeppOS, I recommend checking out this tool.
viewtopic.php?p=14958#p14958
Hopefully it will be of benefit.
Lilonu
Post by Lilonu »
Thank you!
A I create my images in Gimp I'd like to skip that step: Gimp can export indexed, non-compressed, left-top tga files - but I'm a little afraid of (almost) bricking the gts-4 again. So if anybody has tried that already, I'd like to be reassured - or warned ;)
Lilonu
Post by Lilonu »
I had a closer (sourcecode) look at another tool by the same author, SashaCX75, ImageToGTR3 of what asoo mentioned:
asoo wrote: 11 Feb 2024, 04:00
Actually, the files are Truevision_TGA files, but with a few twist (e.g. the width always a multiple of 16 and rgba mirrored to abgr).
Probably better to look at a newer version. But the general principles are the same. The format is based on TGA, but there are some differences (depending on the watch model).
https://github.com/SashaCX75/ImageToGTR3_v2
Return to “Zepp OS”
