Tool to unpack gts 2 mini
Hello guys, I need help about gts 2 mini.
It has passed a lot of time since when I did some wf for this watch, and now I totally forgot which tools to use and where to find them.
To start I'd need a tool to unpack wf, but I'm not able to find anything I could use on windows.
- Has thanked: 419 times
- Been thanked: 2109 times
viewtopic.php?p=12537#p12537Max88 wrote: 23 Jan 2024, 14:15Hello guys, I need help about gts 2 mini.
Thank you. I had already seen that post, but that main.exe file doesn't work for me.
It doesn't unpack wf I have downloaded from this site.
Moreover, to be honest I haven't understood exactly how to use it.
I have imagined it was sufficient to download just the main.exe file and drag the bin I'm interested in on top of that exe.
You can view the command line byMax88 wrote: 23 Jan 2024, 21:11Thank you. I had already seen that post, but that main.exe file doesn't work for me.
Open "CMD" (Dos mode) and type main --help
usage: main [-h] [--vergelite] [--gtr {42,47}] [--gtr2 {42,47}] [--gts] [--gts2] [--trexpro] [--oldformat]
[--gts2mini] [--bipu] [--bip3] [--trex] [--x] [--file FILE [FILE ...]] [--to_raw] [--from_raw]
[--border_alignment]
options:
-h, --help show this help message and exit
--vergelite force VergeLite watchface
--gtr {42,47} force GTR watchface
--gtr2 {42,47} force GTR2 watchface
--gts force GTS watchface
--gts2 force GTS2 watchface
--trexpro force TRexPro watchface
--oldformat force old json format for GTS2 or GTR2
--gts2mini force GTS2 Mini watchface
--bipu force Bip U watchface
--bip3 force Bip 3 watchface
--trex force T-REX watchface
--x force AmazfitX watchface
watchface.bin - unpacks watchface images and config watchface.json - packs config and
referenced images to bin file
--to_raw save raw header and resources
--from_raw generate bin from raw folder
--border_alignment draw border around aligned objects in preview( in the topic "usage" )
Thank you again for help, but where do I have to open CMD and how?asoo wrote: 24 Jan 2024, 02:02You can view the command line by
or you can see how to use main.exe in this link.Code: Select all
usage: main [-h] [--vergelite] [--gtr {42,47}] [--gtr2 {42,47}] [--gts] [--gts2] [--trexpro] [--oldformat] [--gts2mini] [--bipu] [--bip3] [--trex] [--x] [--file FILE [FILE ...]] [--to_raw] [--from_raw] [--border_alignment] options: -h, --help show this help message and exit --vergelite force VergeLite watchface --gtr {42,47} force GTR watchface --gtr2 {42,47} force GTR2 watchface --gts force GTS watchface --gts2 force GTS2 watchface --trexpro force TRexPro watchface --oldformat force old json format for GTS2 or GTR2 --gts2mini force GTS2 Mini watchface --bipu force Bip U watchface --bip3 force Bip 3 watchface --trex force T-REX watchface --x force AmazfitX watchface --file FILE [FILE ...] watchface.bin - unpacks watchface images and config watchface.json - packs config and referenced images to bin file --to_raw save raw header and resources --from_raw generate bin from raw folder --border_alignment draw border around aligned objects in preview
Because if I write cmd in windows task and then I write main --help nothing happens
Edit: oh and I haven't understood how to use that main.exe, sorry.
Open CMD :Max88 wrote: 24 Jan 2024, 08:39
main --gts2mini --file yourwatchface.bin
command line for pack
main --gts2mini --file yourwatchface.json
asoo wrote: 24 Jan 2024, 09:05Open CMD :command line for unpackSpoiler
- Attachments
- Screenshot 2024-01-24 101725.png (23.24 KiB) Viewed 3416 times
if you want to use main.exe , main.exe must be in the same folder as file.bin that you want to unpack.
Or, if you don't want to copy main.exe into the same folder as file.bin, you can copy main.exe into the folder c:\windows or the folder where Windows is installed. Doing this, you can run main.exe anywhere.
Ok, i got it. I have changed the working directory of cmd to the one where main and bin are.asoo wrote: 24 Jan 2024, 09:59if you want to use main.exe , main.exe must be in the same folder as file.bin that you want to unpack.
I have given the command you wrote and unpack has worked.
Thank you a million for your kindness and patience
