Hi
I want to ask you that if I make a dial with two backgrounds, can I set the date, battery status, etc. for each background separately?
or everything stays as it is, just the background changes?
Thank you in advance for your answer
dual background
- Has thanked: 436 times
- Been thanked: 2137 times
I don't know which device you are talking about, such as GTR2 or GTR3 or others.
If it's GTR3 or any other device running Zapp OS, it's possible to define more than one variable for create the same elements much more than one.
But you need to additionally edit it manually in the index.js file.
( by using custom script as you want )
But if it's an amazfit device that doesn't use Zepp OS as an operating system as far as i know Unlikely to do as you say.
- SashaCX75
- Has thanked: 15 times
- Been thanked: 1044 times
In my editor, only the background will change. But if you edit the code in the dial yourself, this can be done.
Rafi87
- Has thanked: 1 time
unfortunately, I can't do it manually, I don't know where and what needs to be overwritten
can't you add it in your program so that it can be done?
