[T-Rex Pro]Black Screen when upload a skin
Fearless-Week
Post by Fearless-Week »
I was dealing with this problem for three days now and I still dont know whats wrong. I was using the SashaCX75 editor (AmazFit Watchface Editor 2) and never had a problem.
The skin looks well with the editor but when I upload it to the watch I get a black screen. Pretty scary cause the watch seems dead.
Here I attached the log from the skin and the skin if anyone want to try it. Any help would be appreciated
g305_T-Rex_Pro_packed.bin
This is the skin where it get a black screen when is upped
(512.36 KiB) Downloaded 201 times
g305_T-Rex_Pro_packed.log
here is the log file of that skin
(231.45 KiB) Downloaded 155 times
Has thanked: 437 times
Been thanked: 2141 times
As far as I've tried checking .json, I can't see anything wrong.
There is only one thing I think that might be the reason why Seeing a black screen is that your preview file is not 0002.png but I'm not exactly sure if it's the cause of the problem. as far as I can remember. GTR2 if the backgorund screen doesn't use 0001 or 0002 sometimes the watchface won't open. and shows a black screen on the real device.
But I'm not sure if the Preview image doesn't use 0002, it will make the watchface can not open or not , and the same requirements on GTR2 is issue in T-rex Pro or not.
On official edit tool , the background screen and preview files are always 0001 and or 0002.
Sample file. Test move preview file to 0002.png file.
I can not test on real device because I do not have T-RexPro
Fearless-Week
Thanks for answering asoo!. I tried what you said, with the preview file as 0002, corrected every value and still have a black screen. In T-Rex Pro (I think) 0001 must be the background image.
Here is the file, corrected with the preview image as 0002, in case someone would like to test it.
g305_T-Rex_Pro.Preview.0002.bin
(511.91 KiB) Downloaded 203 times
Fearless-Week wrote: 26 Oct 2022, 00:24
This watch face is created from the official edit tool.
Since the official edit tool doesn't have a month pointer, this dial doesn't have a month pointer.
you can try installing this watchface on your watch to check it work or not , If it works, try to fix it with SashaCX75's request tool again.
source.bin
(346.55 KiB) Downloaded 174 times
Fearless-Week
asoo wrote: 26 Oct 2022, 02:13
Seems like that editor make this skin work. Thanks! Im going to try to fix the month pointer with the SashaCX75's editor and then I will report what happend
EDIT
Seems like its the SashaCX75 pack the skin differently, with your edition now the skin works!!
Thanks so much!. Now I will need to find that editor you are using. Thanks again!
Fearless-Week wrote: 26 Oct 2022, 14:39
EDIT
official editer :
You must be registered with zepp to use it.
https://developer.zepp.com/os/home
Fearless-Week
Again, thanks so much!
