[T-Rex Pro]Black Screen when upload a skin
Fearless-Week
I was dealing with this problem for three days now and I still dont know whats wrong. I was using the SashaCX75 editor (AmazFit Watchface Editor 2) and never had a problem.
The skin looks well with the editor but when I upload it to the watch I get a black screen. Pretty scary cause the watch seems dead.
Here I attached the log from the skin and the skin if anyone want to try it. Any help would be appreciated
- Attachments
- g305_T-Rex_Pro_packed.bin
- This is the skin where it get a black screen when is upped
- (512.36 KiB) Downloaded 202 times
- g305_T-Rex_Pro_packed.log
- here is the log file of that skin
- (231.45 KiB) Downloaded 156 times
- Has thanked: 437 times
- Been thanked: 2141 times
As far as I've tried checking .json, I can't see anything wrong.
There is only one thing I think that might be the reason why Seeing a black screen is that your preview file is not 0002.png but I'm not exactly sure if it's the cause of the problem. as far as I can remember. GTR2 if the backgorund screen doesn't use 0001 or 0002 sometimes the watchface won't open. and shows a black screen on the real device.
But I'm not sure if the Preview image doesn't use 0002, it will make the watchface can not open or not , and the same requirements on GTR2 is issue in T-rex Pro or not.
On official edit tool , the background screen and preview files are always 0001 and or 0002.
Sample file. Test move preview file to 0002.png file.
I can not test on real device because I do not have T-RexPro
Fearless-Week
Thanks for answering asoo!. I tried what you said, with the preview file as 0002, corrected every value and still have a black screen. In T-Rex Pro (I think) 0001 must be the background image.
Here is the file, corrected with the preview image as 0002, in case someone would like to test it.
- Attachments
- g305_T-Rex_Pro.Preview.0002.bin
- (511.91 KiB) Downloaded 204 times
This watch face is created from the official edit tool.Fearless-Week wrote: 26 Oct 2022, 00:24Thanks for answering asoo!. I tried what you said, with the preview file as 0002, corrected every value and still have a black screen. In T-Rex Pro (I think) 0001 must be the background image.
Since the official edit tool doesn't have a month pointer, this dial doesn't have a month pointer.
you can try installing this watchface on your watch to check it work or not , If it works, try to fix it with SashaCX75's request tool again.
Fearless-Week
Seems like that editor make this skin work. Thanks! Im going to try to fix the month pointer with the SashaCX75's editor and then I will report what happend
EDIT
Seems like its the SashaCX75 pack the skin differently, with your edition now the skin works!!
Thanks so much!. Now I will need to find that editor you are using. Thanks again!
official editer :Fearless-Week wrote: 26 Oct 2022, 14:39Thanks so much!. Now I will need to find that editor you are using. Thanks again!Spoiler
EDIT
You must be registered with zepp to use it.
https://developer.zepp.com/os/home
Fearless-Week
