Watchface conversion to T Rex 2 request
Marsbarsxx
Post by Marsbarsxx »
Anyone able to convert the watchface below to fit on T Rex 2.
https://amazfitwatchfaces.com/gtr/view/27709
Been thanked: 2122 times
Marsbarsxx wrote: 23 Sep 2022, 18:40
Yon can use "Amazfit GT3 Series Watch Face Editor (GTR 3, GTR 3 Pro, GTS 3)" convert to GTR3 , T Rex2 by yourself.
Marsbarsxx
Thanks for the help. Wasn't too hard to convert.
jacppp
Post by jacppp »
Hey, sorry to bother you.
I've tried using the software to convert but couldnt get the hang of it.
Could you convert this TREX watchface : https://amazfitwatchfaces.com/t-rex/view/251?hl=it
to TREX 2 ?
Or shortly explain how to use the program to do it.
Thank you!
jacppp wrote: 19 Nov 2022, 09:47
to TREX 2 ?
Thank you!
As far as know now do not have program convert T-Rex to T-Rex2
If you want to make this watchface , you must to unpack T-Rex watchface and bring that resource to built the T-rex2
You can see all tool in this forum :
viewforum.php?f=29
jacppp
Post by jacppp »
So i've tried and i'm at a good point editing a watchface that i downloaded as zip file, but after using the tool i end up with a .json file, how could i convert it to .bin file in order to actually use it as watchface?
Thank you!
jacppp wrote: 20 Nov 2022, 11:48
Thank you!
which device are you using?
The Trex watchface will have a BIN extension.
The Trex2 watchface will have a zip extension.
If you want to create a watchface for a what device, you must use the editor that matches the device you want.
Editor for Trex2
viewtopic.php?t=2743
Editro for Trex
viewtopic.php?t=1076
and as far as i know , Now do not have program edit can convert, that you talk about.
So you can do only use image resource to built watchface by Editor that support you device.
BarnOwl
Post by BarnOwl »
Hi, is there a way to convert a 47mm watchface to the T-Rex 2 with your program? It is this watchface I am talking about:
