- Amministratore
Watchface conversion to T Rex 2 request
Marsbarsxx
- Has thanked: 1 time
- Contatta:
Anyone able to convert the watchface below to fit on T Rex 2.
https://amazfitwatchfaces.com/gtr/view/27709
- Has thanked: 406 times
- Been thanked: 2031 times
Yon can use "Amazfit GT3 Series Watch Face Editor (GTR 3, GTR 3 Pro, GTS 3)" convert to GTR3 , T Rex2 by yourself.Marsbarsxx ha scritto: 23 set 2022, 18:40Anyone able to convert the watchface below to fit on T Rex 2.
Marsbarsxx
- Contatta:
Hey, sorry to bother you.
I've tried using the software to convert but couldnt get the hang of it.
Could you convert this TREX watchface : https://amazfitwatchfaces.com/t-rex/view/251?hl=it
to TREX 2 ?
Or shortly explain how to use the program to do it.
Thank you!
to TREX 2 ?
Thank you!
As far as know now do not have program convert T-Rex to T-Rex2jacppp ha scritto: 19 nov 2022, 09:47Hey, sorry to bother you.
to TREX 2 ?
Thank you!
If you want to make this watchface , you must to unpack T-Rex watchface and bring that resource to built the T-rex2
You can see all tool in this forum :
viewforum.php?f=29
So i've tried and i'm at a good point editing a watchface that i downloaded as zip file, but after using the tool i end up with a .json file, how could i convert it to .bin file in order to actually use it as watchface?
Thank you!
Thank you!
which device are you using?jacppp ha scritto: 20 nov 2022, 11:48So i've tried and i'm at a good point editing a watchface that i downloaded as zip file, but after using the tool i end up with a .json file, how could i convert it to .bin file in order to actually use it as watchface?
Thank you!
The Trex watchface will have a BIN extension.
The Trex2 watchface will have a zip extension.
If you want to create a watchface for a what device, you must use the editor that matches the device you want.
Editor for Trex2
viewtopic.php?t=2743
Editro for Trex
viewtopic.php?t=1076
and as far as i know , Now do not have program edit can convert, that you talk about.
So you can do only use image resource to built watchface by Editor that support you device.
Hi, is there a way to convert a 47mm watchface to the T-Rex 2 with your program? It is this watchface I am talking about:
