hour dual in face??
murmilega
hour dual in face??
Post by murmilega »
Question, can you make a sphere with dual time? for example Spain and Tokyo, I do not see within the program where it can be done.
thks
Been thanked: 1029 times
It is possible only on an analog clock to draw an hour hand turned at the desired angle, and then the analog time will lag behind or ahead of the main time by a certain number of hours.
murmilega
Post by murmilega »
SashaCX75 wrote: 02 Oct 2021, 08:08
Thank you very much for your answer
