Question, can you make a sphere with dual time? for example Spain and Tokyo, I do not see within the program where it can be done.
thks
- Administrador
hour dual in face??
Reglas del Foro
- SashaCX75
- Has thanked: 13 times
- Been thanked: 1028 times
- Contactar:
It is possible only on an analog clock to draw an hour hand turned at the desired angle, and then the analog time will lag behind or ahead of the main time by a certain number of hours.
murmilega
- Has thanked: 1 time
- Contactar:
Thank you very much for your answerSashaCX75 escribió: 02 Oct 2021, 08:08It is possible only on an analog clock to draw an hour hand turned at the desired angle, and then the analog time will lag behind or ahead of the main time by a certain number of hours.
¿Quién está conectado?
