I've followed all instructions. I get the same result as massi131: Download failed, error code: null. When I put the address that starts with zpkd1:// in the address of my browser I do not get a download (or anything). Though with the http:// I do get a download. Any ideas?supersufa ha scritto: 19 dic 2023, 11:22The most important step is to create the file WatchFace.zip containing:
- device.zip (your favourite watchface renamed)
- app-side.zip (support file here attached)
Then you have to renamed the file in WatchFace.zpk.
Then you have to load the renamed file on altervista.
Then you have to generare the QR code (renaming from http:// to zpkd1://)
Without these steps the intall phase is impossible!
Thanks for everything! Your answers and this thread are super helpful!
