Amazfit Balance
MikeZuul
Post by MikeZuul »
supersufa wrote: 19 Dec 2023, 11:22
The most important step is to create the file WatchFace.zip containing:
- device.zip (your favourite watchface renamed)
- app-side.zip (support file here attached)
Then you have to renamed the file in WatchFace.zpk.
Then you have to load the renamed file on altervista.
Then you have to generare the QR code (renaming from http:// to zpkd1://)
Without these steps the intall phase is impossible!
I've followed all instructions. I get the same result as massi131: Download failed, error code: null. When I put the address that starts with zpkd1:// in the address of my browser I do not get a download (or anything). Though with the http:// I do get a download. Any ideas?
Thanks for everything! Your answers and this thread are super helpful!
Has thanked: 414 times
Been thanked: 2073 times
MikeZuul wrote: 11 Jan 2024, 20:32
The url you used What does it look like?
Is the url direct to .zpk?
For example:
xxxx.com/watchface/xxxx.zpk
Because if it's a url that must be processed through the system before downloading, it may not work.
I don't use altervista in the process. So I'm not sure what format the url you got is.
However, if you can post the url that you receive from your download
I will be happy to test for you if the url is usable or not.
I use web pcloud to do this.
When the download was finished, I copied t "direct Download" url to use.
Created a QR code and I was able to sync the watch face through App Zepp in developer mode to "Balance" without any problem.
MikeZuul
Post by MikeZuul »
http://mikezuul.altervista.org/WatchFace.zpk
And then I make it zpkd1://mikezuul.altervista.org/WatchFace.zpk and make a qr code from that.
MikeZuul wrote: 12 Jan 2024, 17:27
I think issue maybe is on the hostting or your pack file because after try to download firefox show this message
However, today I noticed that https://amazfitwatchfaces.com Added a section for the "Amazfit Balance" "File Download". That add in section is a QR code that can be used with the Zepp App. I have tested it and the QR code works fine.
Stephthouv
Has thanked: 7 times
Post by Stephthouv »
"" However, today I noticed that https://amazfitwatchfaces.com Added a section for the "Amazfit Balance" "File Download". That add in section is a QR code that can be used with the Zepp App. I have tested it and the QR code works fine.""
You're right and it works fine!.. Also with gtr3 pro faces. Many thanks for this!
MikeZuul
Post by MikeZuul »
I'm not sure where I'm at with my file, but I tried the qr code now on the site and it works! And for GTR 3 Pro as well. So thank you for the heads up! And thank you Amazfitwatchfaces!
enryko92
Post by enryko92 »
Yes, i confirm that with the updated app it works with QR on Android. Just click "download" and then the QR icon. Send the picture to the pc and scan it
ianna
Post by ianna »
Stephthouv wrote: 12 Jan 2024, 19:11
Hi guys. I'm trying but I don't see the "File Download" section.. where is it :roll:
Has thanked: 1137 times
Been thanked: 275 times
ianna wrote: 11 Mar 2024, 16:53
ianna
Post by ianna »
thank you
mogulman
Post by mogulman »
So what's the best way to install on a Balance these days?
I used the QR Card 3 watch app to create a QR code with the second number from the watchface, and then scan using developer mode. It seemed to work.
Is the an Amazfaces QR code watch app anymore? I couldn't find it.
Is it possible to just download the watchface to my phone storage and then use developer mode to upload it to my watch?
mogulman wrote: 25 Jun 2025, 01:27
https://amazfitwatchfaces.com/awapp
Alpha775@
Post by Alpha775@ »
:x A few days ago, the QR Amazfit app disappeared from my Balance, and since then I’ve tried reinstalling it several times without success. I still have the AmazfitFaces app, but without QR Amazfit I can no longer install anything.
If the app’s QR download worked, it would be much more practical. I need to understand why the QR AW is not installing on the Balance.
Alpha775@ wrote: 03 Sep 2025, 19:11
It’s hard to say why you can’t reinstall the QR Amazfit app on your Balance, but the good news is that you don’t actually need it anymore. You can install everything directly through the official Zepp app in developer mode by scanning the QR code saved from AmazFaces. This method works reliably without requiring the extra app.
  • Save the QR code to your phone’s gallery.
  • Open the QR code scanner in Zepp Developer Mode.
  • Tap “Open Gallery” in the top-right corner.
  • Select the saved QR code imag
Alpha775@
Post by Alpha775@ »
I’ve tried saving the QR Code several times, but when I go to look for it, it simply doesn’t appear.
In other apps the QR Code downloads normally, but with AmazFaces it doesn’t work on my Android.
An alternative would be to generate the QR Code directly on the screen and then allow the download. This way, if the download fails, I could still take a screenshot.
Alpha775@ wrote: 05 Sep 2025, 17:02
Thanks for the feedback! There’s also a button to re-save the QR code (Save QR to Gallery) in case it didn’t appear the first time. Could you check if that works for you as well? If it still doesn’t show up, please let us know your Android version and device model so we can investigate further.
Alpha775@
Post by Alpha775@ »
Hi.
I tried again to download the QR Code, but it still doesn’t work.
When I click to download, only the Watchface image is saved to my gallery, not the QR Code.
My phone is a Galaxy S20 with Android 13 and One UI 5.1.
What’s strange is that, at the beginning of August, I was able to install everything normally through the AW Code app on Balance. However, after this app disappeared from the watch, I have not been able to install Watchfaces anymore.
Now, whenever I try to download the QR Code, it only saves the Watchface image. I also use another app that generates the QR Code directly on the screen and allows downloading, and with that one it works perfectly.
Print 👇👇👇
Stas
Been thanked: 34 times
Post by Stas »
Hi, thank you for letting us know! We really appreciate your feedback.
In the next 1–2 days we’ll release an update that will let you save the QR code properly through the selected path.
Alpha775@ wrote: 08 Sep 2025, 14:00
Hi.
Print 👇👇👇
Alpha775@
Post by Alpha775@ »
Today I downloaded some QR codes, but it still only saves the watchface image and doesn’t include the QR code.
I hope you can fix this QR code issue.
Tks
Stas
Post by Stas »
We’ve uploaded the new version 4.7.404 to the beta channel today. It will be tested during the day and then released as a stable update. If you encounter any difficulties, please let us know.
Alpha775@ wrote: 11 Sep 2025, 19:27
Tks
Alpha775@
Post by Alpha775@ »
Do you know if version 4.7.404 has already been tested and where this update will be available for download?
Tks.
Stas
Post by Stas »
We’ve just released version 404. If you’d like early access, you can already download it from beta testing here: https://play.google.com/store/apps/deta ... chfaces.st.
Alpha775@ wrote: 16 Sep 2025, 20:25
Tks.
Alpha775@
Post by Alpha775@ »
It’s really working now and it turned out very good. It’s no longer showing any issues. Congratulations on the fixes, the installation has even become more practical.
tks
Return to “AmazFaces app”
