- Amministratore
Collaboration Request
MSKefayati
- Has thanked: 3 times
- Contatta:
- SashaCX75
- Has thanked: 13 times
- Been thanked: 1036 times
- Contatta:
If you send new colours in the same format (with this file and folder structure), it is not difficult for me to add them. But you need to check how such a big watch face will be installed on the watch. Perhaps it will not be installed at all or will take a long time to install.
As an option you can make several watch faces with different set of colours.
MSKefayati
- Contatta:
Good! So I will make them for you. You can decide the approach as the programmer.
- SashaCX75
- Contatta:
I'm a little confused.
The hour hand should change colour on the main screen and on the AOD screen.
The minute hand changes colour on the main screen. On the AOD screen it's always black.
Do you want this kind of work? Here is a variant with such minute hand work. But note that the size of the minute hand for AOD mode is a little smaller. Is that correct?
- Allegati
Spatial Number 466x466.zip- (3.57 MiB) Scaricato 124 volte
- SashaCX75
- Contatta:
If you want to add more colours, send only new colours. Well, it is necessary to include in the archive what has not changed. So it will be easier for me to understand what has been added or changed.
MSKefayati
- Contatta:
Ok. Sure. I will but the in watchface I had tested a few numbers and uv indicators and icons colors changed to match the main color so please replace those two assets as well.
- SashaCX75
- Contatta:
Updated the images in those folders.
- Allegati
Spatial Number 466x466.zip- (3.57 MiB) Scaricato 105 volte
MSKefayati
- Contatta:
Thanks Sasha! Any plan about publishing? Do you let me publish it or you yourself want to publish it?
- SashaCX75
- Contatta:
- SashaCX75
- Contatta:
@MSKefayati
Can you share sources of large numbers in psd format? There is a person who wants to try to make animation of numbers.
MSKefayati
- Contatta:
Thanks Man!! I will do it definitely!SashaCX75 ha scritto: 25 dic 2024, 19:19You can publish it yourself. Just specify me as the author of the code.
MSKefayati
- Contatta:
Yeah sure.SashaCX75 ha scritto: 06 gen 2025, 16:40@MSKefayati
https://drive.google.com/file/d/1RQ1341 ... sp=sharing
- SashaCX75
- Contatta:
@MSKefayati
This watch face is still in development, but the author shared a test version. Watch face is designed for 480x480 screen, but should run on other models. The animation of numbers is switched on by a quick tilt of the watch and by tapping on the screen. Colour switching is done by rotating the crown.SashaCX75 ha scritto: 06 gen 2025, 16:40There is a person who wants to try to make animation of numbers.
MSKefayati
- Contatta:
I don't know why but the app doesn't accept the qr code at all(doesn't react when I choose it from gallery.) I also try to invert the image but it didn't work.
- SashaCX75
- Contatta:
The author has updated the dial a bit. This one definitely works on GTR4 but it doesn't match the size. Just in case I added another dial file.
- Allegati
SamBig.zip- (109.19 KiB) Scaricato 116 volte
MSKefayati
- Contatta:
I've just test it now. it Looks so cool.
just two problem. Idon't know why the white section is all blur(the edges should be sharp)
the blue color has a problem(at least at 9 o'clock)
Never the less it's perfect.
- SashaCX75
- Contatta:
It is not possible to make a blur effect (frosted glass) on moving images. That's why the author replaced it with the usual image opacity.
If you are talking about problems with the blue circle, the author knows about it.
MSKefayati
- Contatta:
Ok. As I said I know it's replaced by usual opacity. I meant I feel the edges of half white sections of numbers are not as sharp as color parts.SashaCX75 ha scritto: 21 gen 2025, 19:39It is not possible to make a blur effect (frosted glass) on moving images. That's why the author replaced it with the usual image opacity.
Visitano il forum: Nessuno e 14 ospiti
