Collaboration Request
MSKefayati
Post by MSKefayati »
It can be! How many more colors you think we can add?#
Been thanked: 1029 times
If you send new colours in the same format (with this file and folder structure), it is not difficult for me to add them. But you need to check how such a big watch face will be installed on the watch. Perhaps it will not be installed at all or will take a long time to install.
As an option you can make several watch faces with different set of colours.
MSKefayati
Good! So I will make them for you. You can decide the approach as the programmer.
I'm a little confused.
The hour hand should change colour on the main screen and on the AOD screen.
The minute hand changes colour on the main screen. On the AOD screen it's always black.
Do you want this kind of work? Here is a variant with such minute hand work. But note that the size of the minute hand for AOD mode is a little smaller. Is that correct?
Spatial Number 466x466.zip
(3.57 MiB) Downloaded 122 times
If you want to add more colours, send only new colours. Well, it is necessary to include in the archive what has not changed. So it will be easier for me to understand what has been added or changed.
MSKefayati
Ok. Sure. I will but the in watchface I had tested a few numbers and uv indicators and icons colors changed to match the main color so please replace those two assets as well.
MSKefayati wrote: 22 Dec 2024, 17:40
Updated the images in those folders.
(3.57 MiB) Downloaded 104 times
MSKefayati
Thanks Sasha! Any plan about publishing? Do you let me publish it or you yourself want to publish it?
You can publish it yourself. Just specify me as the author of the code.
@MSKefayati
Can you share sources of large numbers in psd format? There is a person who wants to try to make animation of numbers.
MSKefayati
SashaCX75 wrote: 25 Dec 2024, 19:19
Thanks Man!! I will do it definitely!
MSKefayati
SashaCX75 wrote: 06 Jan 2025, 16:40
@MSKefayati
Yeah sure.
https://drive.google.com/file/d/1RQ1341 ... sp=sharing
@MSKefayati
This watch face is still in development, but the author shared a test version. Watch face is designed for 480x480 screen, but should run on other models. The animation of numbers is switched on by a quick tilt of the watch and by tapping on the screen. Colour switching is done by rotating the crown.
MSKefayati
I don't know why but the app doesn't accept the qr code at all(doesn't react when I choose it from gallery.) I also try to invert the image but it didn't work.
The author has updated the dial a bit. This one definitely works on GTR4 but it doesn't match the size. Just in case I added another dial file.
SamBig.zip
(109.19 KiB) Downloaded 115 times
MSKefayati
I've just test it now. it Looks so cool.
just two problem. Idon't know why the white section is all blur(the edges should be sharp)
the blue color has a problem(at least at 9 o'clock)
Never the less it's perfect.
It is not possible to make a blur effect (frosted glass) on moving images. That's why the author replaced it with the usual image opacity.
If you are talking about problems with the blue circle, the author knows about it.
MSKefayati
SashaCX75 wrote: 21 Jan 2025, 19:39
Ok. As I said I know it's replaced by usual opacity. I meant I feel the edges of half white sections of numbers are not as sharp as color parts.
