Describe in more detail what you want to get. Preferably a Sketch of your watch face design.
I haven't seen the Spatial Number watch face work, and in the preview it always shows the same numbers, so it's not clear what it is. Also need to know if you want to change only these numbers or if other ...
La ricerca ha trovato 3 risultati
- 29 mar 2025, 08:08
- Jump to forum
- Jump to topic
Re: Lunar Watchface
You can't do what you want in the editor. You have to edit the code to do it.
1. To display the alarm clock time you can make any widget in the editor instead of it and place it in the necessary place. It is better to use for this distance or sunrise, because they have a separator in the data. And ...
- 14 apr 2022, 13:29
- Jump to forum
- Jump to topic
Re: Request for GTS2 mini
Bip 3 , gts2 mini , Bip U
You can try to do by yourself by use Editor on web.
https://tnxec2.github.io/amazfit-gts2mini-watchface-react/
https://github.com/Tnxec2/amazfit-gts2mini-watchface-react/archive/refs/heads/gts2mini.zip
if you want to see new version ...
