How to use it.
代码: 全选
GTR2_Packer.exe -unc2 WATCH_FACE_FILE.bin3. Now you can parse uncompressed dial with a command
代码: 全选
python main._py --gtr2 47 --file WATCH_FACE_FILE.binAs a result, if everything was ok, you should receive json file.
代码: 全选
python main._py --gtr2 47 --file WATCH_FACE_FILE.json6 . Pack a new bin file with help of GTR2_Packer.exe
代码: 全选
GTR2_Packer.exe -cmp2 WATCH_FACE_FILE_packed.binNotes .
代码: 全选
-cmp2 Compress gtr2(gts2) bin
-unc Decompress
-unc2 Decompress gtr2(gts2) binCurrent version 0.2
Chagelog
v0.2
Added widgets.
